All Other Toyota Swaps I4, I6, Lexus V8
7mgte swap w A340F tranny
Old May 15, 2012 | 08:33 PM
T-dog's Avatar
Hi I have a 87 4runner w an A340F tranny and a 89 7mgte engine w ecu (auto of coarse). I know the 7m bolts to the tranny bell housing but am curious if the ecu would work for the tranny? Or does the ect control the tran? Is this a realistic swap or should I look into a manual option instead.
Old May 16, 2012 | 02:42 PM
R.DesJardin's Avatar
Are you sure you have an A340F not an A340H?????? Control systems should be able to be adapted from one to the other, not sure if the 7M TC will fit a 22r trans front pump though. Better do some searching and researching no pun intended.
Old May 16, 2012 | 08:13 PM
T-dog's Avatar
It is a A340f w a chain driven transfer case on a 22r engine. I will defiently do more research but i know the ppl on these sites r the pros w this kinda of stuff. With every electronic manual I have looked at the two trannys seem very similar except the 4wd and the wirung set up. I was hoping to do the swap, bolt the tranny and move everything back to accommodate the extra engine length. So are these trannys controlled by the ecu or the ect? Have anyone heard of this being done?
Old May 17, 2012 | 10:08 AM
A340's
If you are positively sure it is an F model, which by the way is very unlikely, you should have a fairly simple control rewire swap. If you have a H model, throw it away and get a different trans. Easy to check, 1 oil pan or 2 oil pans on the trans, 2 is bad.
Dieselmann
Feb 19, 2019 02:57 AM
mskalmus
May 28, 2017 07:51 AM
yourrealdad
Jul 21, 2015 11:13 AM
Iceman4193
Jul 15, 2015 04:48 PM
madxman21
Jul 9, 2015 10:26 AM
