1UZ-FE into 1988 4runner 3.0 3vze
#303
ok so i finally got around to painting my crossmember, had to use a wire wheel on the thing it was getting pretty rusty., i also trimmed it up a little.i used some rustoleum rusty metal primer and satin.
i may trim 2 to 3 inches off the back end of the crossmember also. not sure yet.
i also was running dual batteries before this swap , now im gonna go ahead and but them back in , i made the battery tray today along with painting it . no pics but ill try to install it tomorrow after all the excitement.
#307
That's lame about your radiator. You just got a bad one but it will probably hold up just fine. That's definitely a nice flat skidplate. I've been drooling over some skidplate concepts I want to make.
#309
yea i here you on on the spare time thing .. been pretty busy my self ...
this week
removed two 3.0's
installed a 3.0
did a timing belt water pump job on a 3.0
full time regular job
rebuilt a steering pump
started on rebuilding a 3.0 block
and started on another 1uz swap. Buuusy, i like it though..and i still find myself gaining weight..
if your find yourself around winchester and moorpark in the evenings let me know so you can stop by..
this week
removed two 3.0's
installed a 3.0
#311
No Paul .. im not really comfortable doing it for some one else yet .. i did mine and there ok but i wouldnt want you to spend alot of money and then have me screw them up..
ok it was a busy day today
went to my sons game this morning , then did a timing belt water pump job then rebuilt another power steering pump. I will switch them out tomorrow hopefully. Hope it lasts a long long time ..
#312
and thanks man ..hows your running ?
#314
No problem Paul .. Good luck .
So I actually installed my rebuilt pump along with a 3rd 10" fan at the radiator .. hopefully that will keep the radiator from getting any worse.
#315
well my rebuilt power steering pumps holding up fine .. but now my alternators finally going out , so i thought id upgrade while im replacing the old one .
from 100amp original to 145 amp rebuilt denso
ended up buying this of ebay.
http://cgi.ebay.com/ebaymotors/ws/eB...fvi%3D1&_rdc=1
will intall it tonight ..
#317
the cars have a 120amp fusible link
7.5 eng
7.5 ign
40 amp
http://www.lextreme.com/Lexus-Alternator.html
http://www.lextreme.com/alternator.html
#319
everything ive read tells me they are either 80amp or 100amp
7.5 eng
7.5 ign
40 amp
7.5 eng
7.5 ign
40 amp
The information in the links above appear to be referencing the 1UZ alternator found in the earlier LS400s, which contain a 100amp alternator, protected by a 120amp fusible link. The SC400's contain a 130amp alternator, protected by a 150amp fuse. Later LS400's may contain a 130amp alternator, and a few newer Toyota models (Highlander, Sienna, etc) contain 100 or 130amp alternators, depending on options (V6, rear A/C, etc..).
#320
Both of you are correct, in a sense
