All Other Toyota Swaps I4, I6, Lexus V8
1jz swap
Old Mar 18, 2011 | 12:14 PM
ADIGA's Avatar
alloo !?!
Old Mar 20, 2011 | 12:36 PM
DeathCougar's Avatar
I was on vacation in Cali, sorry bout that!
The turbo trans was 86-87 turbo pickup only
Old Apr 3, 2011 | 05:11 PM
Hadmatt54's Avatar
The 1jz with the R154 behind it uses a pull type clutch. The r151f uses a push type clutch. This is not such a big deal the transmission really doesn't care what type of clutch is in front of it, but the problem is the input shaft on a r154 is about 1 1/8 (30mm) longer than the input shaft of a r151f.
If you read on the Marlin Crawler board the transmissions look the same, but the 1st gear is part of the input shaft and the cluster gear of the r154 will not match the r151f, so in other words you can't swap the input shaft of r154 into a r151f.
What you want to do with your truck? If you want the r151f for the low 1st. gear for serious off road use you are going to have to build a custom bell housing because the input shaft will not seat in the pilot bearing and there will be throw out bearing issues with the 1JZ stock bellhousing. However the tailhousing of the "r" series transmissions are all the same, so you can swap in the output shaft and tailhousing of a r151f on the r154 and run a gear transfer case or you can swap the output shaft and tailhousing of the r150 and use a chain transfer case, but you will not have the lower transmission gearing that is sought by most off roaders.
If you are not really concerned about the gearing of the r151f or you don't necessarily need a gear driven transfer case, then you can use the mid 90's r150 that was behind the 3.4 v6, the input shaft on this transmissions is 1 " (25.4 mm) longer than the input shaft of the r150 that was behind the 3.0 and almost the same length as a r154 about 1/8 (4.6mm) shorter. This should bolt right up to the 1jz bellhousing.
Old Apr 4, 2011 | 07:21 AM
82yota's Avatar
Being as you are in the middle east there are probably quite a few diesels around there as well. The 1kz-te 3.0L TD uses the R151 trans and I am pretty sure the 3L 2.8L NA diesel does too along with the 2LTE. Those are some more choices for you to look at. They have the same length input shaft as the 3.0L V6 3vze. They should work just fine.
Old Apr 4, 2011 | 02:39 PM
  #25
Hadmatt54's Avatar
With an input shaft the same length as the R150 that is behind the 3vze, these transmissions will not work with the stock r154 / 1Jz bellhousing (30mm too short). So a custom bellhousing is the only way to make these work.
Old Sep 18, 2011 | 02:20 AM
  #26
671KOGTOYOTA's Avatar
i want to put a 2JZGTE in my 94 toyota pick up
i want to do a 2jzgte swap in my 94toy 2WD pickup. I know im gonna need motormounts, but does anyone know where to get a drive shaft that will fit the r154 trans i have an 8in rear with 4.56 gears? and a rear sump oil pan and strainer? Will a 7MGTE need custom motor mounts or will it fit right in ?
thank you
Old Sep 22, 2011 | 07:46 PM
  #27
kalmah's Avatar
The 7M-GTE will drop right in with 5M motor mount brackets.
sanctfy
Sep 15, 2015 02:52 PM
exporunner
3.4 Swaps
Aug 3, 2015 06:10 PM
RobotMoose
Diesel Swaps
Aug 2, 2015 11:00 PM
Gevo
Jul 29, 2015 11:15 AM
GeoRoss
Jul 24, 2015 03:03 PM
