All Other Toyota Swaps I4, I6, Lexus V8
1988 4runner 1uz swap
Old Jun 3, 2011 | 01:46 AM
  #101
an1mal_69's Avatar
Hmmmm.. 'lathe' nice work man!!
Post #80, 2nd pic.. The green, round plug.. is that the 2nd diagnostics port? Can't find it on my loom. Cant recall leaving anything in the car, but it sure ain't there. I'll just have to gather the wires and find a plug later.
Old Jun 4, 2011 | 08:34 AM
  #102
RMA's Avatar
RMA
no its not the diagnostic port.. thats from the 4runner harness off hand i dont remeber what it was but that green plug was on the drivers side fender .
the 2nd lexus port was under the dash the 1st was on the engine
Old Jul 6, 2011 | 07:07 PM
  #103
SHAGGY21's Avatar
wow man you are getting this down to an art. i wanna do another one after this one but an 82 long bed and make the cab longer and the bed a little bit shorter but an auto and a supercharger.
Old Jul 11, 2011 | 05:48 PM
  #104
RMA's Avatar
RMA
not quit shaggy .. i wish though, theyve all been a little different in one way or another .
and as far as this one i havent touched it in about 2 weeks ..havent done anything to it at all .. been really busy at work lots of over time along with a couple bathroom remodel side jobs .. just finished those and now this guy wants his kitchen redone .. actually just lucky my friend the owner of this grey 4runner is low on cash right now also.. between this grey one and he also has a 88 red runner hes working on hes spending some money..
Old Jul 11, 2011 | 05:59 PM
  #105
SHAGGY21's Avatar
well as soon as i get some money ill get those covers from you.
Old Jul 11, 2011 | 06:11 PM
  #106
RMA's Avatar
RMA
no problem man .. ill ship them out to you and you can pay me when you can .. be happy to clear even just the covers out from here. send me you address again so i dont have to spend hours looking for it please
Old Jul 26, 2011 | 09:24 PM
  #107
RMA's Avatar
RMA
so not much to report here .. just thought id show the sc 400 fuel pump in the 4 runners fuel pump bracket . its pretty much a simple swap over you just need the sc fuel pumps connector since the 4runners wires are bolted to the pump and dont use a connector .
Old Sep 4, 2011 | 04:41 PM
  #108
RMA's Avatar
RMA
ok , alittle update .... the truck starts and idles fine .. the only wiring needed is the extra A/C relay I need to add (to change the positive signal to negative) and the temp sensor for the fans . heres some pics ..i still need to put the dash back together , install the radiator and drive shafts.
Old Sep 5, 2011 | 06:31 AM
  #109
toyminator2000's Avatar
Good work as always RMA. I'm gonna be starting my 2nd swap with my 88 4Runner here in a couple of months and I want the A/C to work on this one so I may need to hit you up for some detailed info on that.
Old Sep 6, 2011 | 08:16 PM
  #110
RMA's Avatar
RMA
Thanks man .. and when you ready let me know , ill try and post the info on the A/C here soon .
so this 4runner is GONE!! did my part it starts fine idles good ..
the owner will finish it up this is whats left
drive shafts
radiator
fans
RX7 intake boot (to get rid of the aluminum tape on the intake)
once he gets those done hell bring it back to finish some details , the ecu will be moved (want him to drive it before i cut up the harness some more) under the passanger seat .
The Kick down switch will be installed (Ls 400 switch is a little smaller than the current sc 400 one)
the 4wd light in the dash will be connected , its all there just need some connectors off the t-100 do it nice and not just splice the wires together.
heres how she left
and heres the next one it also belongs to the same guy and he wants the swap done to this one to.. told him to Wait! ..maybe 1 or 2 months ..
Old Sep 7, 2011 | 04:24 AM
  #111
RBX's Avatar
RBX
RMA, how many UZ swaps do you now have under your belt?
Old Sep 7, 2011 | 08:57 AM
  #112
an1mal_69's Avatar
Nice work..got the engine pretty far back, plenty of room for a fan in there too.
Old Sep 8, 2011 | 08:16 PM
  #113
RMA's Avatar
RMA
just a couple bro.
yea there is .. its got about a 1/4 inch at the back , with solid mounts.
it will be getting the stock oem radiator(recored to 5 rows) with the 3 small fans .. plenty of room .
Old Nov 17, 2011 | 08:06 PM
  #114
Reynoso's Avatar
Hey tienes que darme un poco de credito cabron presumido, jajajaj
Old Nov 18, 2011 | 07:30 AM
  #115
Moustache's Avatar
Man i wish i had your wiring skills! Good job as usual RMA
Old Nov 18, 2011 | 09:21 AM
  #116
tj884Rdlx's Avatar
Originally Posted by RMA
that right there is a thing of beauty. i am jealous.
fantastic work, man. particularly with the detail to the cluster. i'd love to see a pic in the dark with it all lit up. i miss my '90 LS; love that motor and wish i could justify buying premium fuel or i'd still have it.
when you're able to figure out a flat price for the conversion, please let us know and we'll be lining up to place orders!
really, fantastic work.
Old Nov 28, 2011 | 06:56 AM
  #117
maniacmotorsports's Avatar
AWESOME WORK!!!! Custom Component Engineering could use a slick cat like you!! lol
I was wondering your thoughts on moving the brake booster up a tad? I am going to do a test fit in mine in the next couple days and I really dont want to do a body lift. Do you think I can get away with getting it low enough gaining clearances by masaging oil pan combined with moving booster? I plan on solid mounts on this one. Even if I need to dent the firewall, I want this puppy as far down and back as it will go.
Old Nov 28, 2011 | 06:43 PM
  #118
RMA's Avatar
RMA
no i dont think so ..
https://www.yotatech.com/forums/f161...runner-211832/
in this swap we made a whole new oil pan (Frankenpan) .. we got the engine way down with out a body lift and the booster was not in the way any more....but when it came time to put the tranny on the tunnel was hitting the trans and transfer case.. so we had to put on a body lift anyway .. after all that we really didnt need to make the pan after all .. it did help alot in lowering the engine.. but making a new pan is not necessary either .. the owner wanted the engine as far down as possible and hes very happy with it .. but in my opinion its actually to far down in there.
one other thing.... the other day i found this toyota adapter in the junk yard off a corrolla early 90's .. it is a genuine toyota adapater from mechanical to electronic speed sensor .
heres the part number
83181-20040
and check this link out its technical drawing of the adapter.
http://www.linkecu.com/support/docum...otaSpeedSensor
Old Nov 28, 2011 | 06:52 PM
  #119
RMA's Avatar
RMA
Hahaha .. So the student wants some credit .. ok ok thank you very much for wiring up the cluster and finishing the ignition circuits in the truck but i cant thank you in every post ok... y no estoy pressumiendo way!! nomas esto dando lo que a prendido a los de mas .. ohh que, nomas queries que te ensenia a ti como haser mechanico chingon... jajajaja!!!
thanks bro .. hows your coming along?
man i wish it was that easy .. so many ways it can be done and everybody wants it different ,of course some ways are easier than others . but i can give you a ball park .. $2500-$5000 labor only
Old Nov 29, 2011 | 06:12 AM
  #120
83181-20040
much thanks bro, looks like I have no choice but to do a lift..just for the hell of it, I am going right now to do a test fit. Oh, do you happen to have an extra 26 pin clip for the 4th port by itself on a 90 LS400 ecu?
