Lysmachia's CAB/Engine Swap for Tippy
Old Jun 19, 2010 | 12:15 AM
  #121
Lysmachia's Avatar
Yeah I am not sure as to why Troy and the crew mounted them that way. It might have something to do with the shock mounts of the 85 frame/Body.... Hopefully TC *Troy) will chime in on that.
The front and rear bumpers were done custom by All Phase from Longmont, which is sadly out of business... It took Troy 3 days to cut the front bumper off the old tippy because All Phase had really welded it on there! This is the bumper that will be going on Tippy II
Old Jun 19, 2010 | 12:59 AM
  #122
whokrz's Avatar
Congrads on getting tippy running again, its looking good.
Old Jun 19, 2010 | 02:44 PM
  #123
Lysmachia's Avatar
So apparently those of us (myself included) who put the alternator back, forgot to plug in the 2 wires that connect it to the battery. (Another guy had taken it out) We drove it quite a while until it started dying near our house... I'm super glad Troy helped me figure it out. From now on If I work on something, It has to be from start to finish, otherwise I won't know about the parts that were disconnected! I gotta do it MrDoug style... By myself or with one other person and be able to lay the parts out so I know which order to put it back together! Apparently my next Job from Troy is to steam clean the engine bay.... Oh boy!
Anyone in Colorado have a steam sprayer or cleaner (I mean boiling water) to clean the engine bay. That purple cleaner isn't gonna cut it.
Old Jun 23, 2010 | 08:26 PM
  #124
aviator's Avatar
Well you can always get one of those pesticide spray pump thingies and fill it with HD degreaser. Take tipster to a coin wash and with her running gently pressure wash the loose dirt out... than go at the caked grease with the degreaser and let it sit a bit then press. wash again.
You may need to do this at night so you don't p off too many other peeps or get static for oiling up the wash bay...
just an idear...
btw did that 3.0 alt. fit the 22re?
Old Jun 23, 2010 | 10:19 PM
  #125
Lysmachia's Avatar
Muah Ha Ha! Tippy2 gets revenge!!! (Mashing the cab and frame of Tippy I before it was hauled off to scrap! BUH BUY Tippy I! Hello Tippy2
Tippy2 gets her bumper on tomorrow too!
Old Jun 27, 2010 | 04:20 PM
  #126
Lysmachia's Avatar
OMG! I have my Truck back!
Tippy II drove really well for the most part on Friday on Left Hand doing Big Motha Hill and then the parts further up on Left Hand 286 D. Having less weight up top and in the engine compartment definitely made a huge difference. The suspention issues seemed a lot better with a lighter engine and top. Even my All Pro springs are no longer de-arched!
Yes this was me actually driving...
Old Jun 28, 2010 | 09:36 AM
  #127
aviator's Avatar
WOOHOO! good for you girl!
Old Jul 12, 2010 | 11:36 PM
  #128
Lysmachia's Avatar
MMM... Tippy II + Rocks + Muddy Water = Love
http://www.facebook.com/video/video....=1494816497893
Old Jul 24, 2010 | 07:44 PM
  #129
Lysmachia's Avatar
So we busted into that 22re today to do the timing chain...
Here's Troy's report:
Originally Posted by RedRunnertc
We changed the timing chain today - guides were DEFINITELY toasted (thanks for the heads up Russ!). Got it before it wore through the cover.
Went to start it and .... no go. As hard as I tried, I bet something got rotated and the cam timing is way off. Unfortunately, we won't have any time to look at it before I leave for Houston
Can someone come over, and help her get everything timed right? We have all the tools (including timing light) - just need someone with the mechanical inclination to line it up to TDC, pull the distributor and valve cover, and line up the cam and distributor to TDC.
Thanks!
Yeah it was on par with doing Troy's water pump.... There was some cursing and tool throwing (and a freaking seizure thrown in for good measure)... But as troy said we just need to get it lined up right.
And Troy is a rock star for helping me do this (more like me helping him do it) right before he leaves for Houston....
Old Aug 8, 2010 | 12:49 AM
  #130
Lysmachia's Avatar
So an update. After Troy left, I got a Tech to come walk me through the Timing chain. I honestly love that motor. I can now tear it down myself! We got her purring like a kitten... UNTILL..... We went to take her up to Holy Cross and on the way the Tranny pump went out. Now the Cab/engine/tranny are only 3 months old to us. I could tell it shifted a little hard. Shoulda known the tranny was about to go. It's at 190K and who knows what the PO did with it. So I'm hunting for a 22re Auto Tranny that I'll have re-built. Not sure I have time to do the manual swap as really Tippy needs to be running by Aug 22 to get on the Car Hauler for Houston.
Poor Tippy. She looked so sad on the AAA tow rig....
But at least once i get that done, I'll know that she's in good shape and should run without issues for awhile!
Old Aug 8, 2010 | 07:31 AM
  #131
Lysmachia's Avatar
Bump for mah carnage!
Old Aug 8, 2010 | 09:21 PM
  #132
aviator's Avatar
Sorry to hear you need a tranny... slush boxes suck... manny's rule.
Not sure if the brain box is the same if you do a conversion IK the 3.0s are diff.
good luck. stay zen
Old Aug 9, 2010 | 12:32 AM
  #133
Lysmachia's Avatar
Yeah, I think a manual conversion is in order down the line... with a crawl box of course. The input I am getting from CoTTORA is slap the other one I got in, and re-build the trashed one... which I actually want to tear into myself once I get settled in Houston.... If not to just really understand an Auto Tranny...
sanctfy
All Other Toyota Swaps
Sep 15, 2015 02:52 PM
exporunner
3.4 Swaps
Aug 3, 2015 06:10 PM
RobotMoose
Diesel Swaps
Aug 2, 2015 11:00 PM
Gevo
Jul 29, 2015 11:15 AM
GeoRoss
Jul 24, 2015 03:03 PM
