Body Lift for 3.4 swap on 1988 4Runner
Old Aug 27, 2014 | 09:09 AM
Zorlac's Avatar
Hello everyone
I have a query
soon hope to do a swap in my DD is a 1988 4runner 3.0 v6 5spd (First gen model)
the donor vehicle is a 2001 4runner 3.4 v6 AT
˟ I have read a lot on this forum about the 3.0 to 3.4 swap
but before putting my hands, the motor is 3.4 larger than the 3.0
and solve it enters the engine compartment necessary or hood scoop or
one body lift, I want to go for the option of the body lift, but I want to be the bare minimum required, with BL 1.5 "would be fine ?, considering I want to keep the IFS system on the 4Runner
Greetings!
my ride
https://www.yotatech.com/forums/f116...l#post52218936
Old Aug 30, 2014 | 10:47 AM
vwrunner's Avatar
I also have a 1988 4Runner, by mine originally had a 22RE. I already had a 2 inch body lift and a 2 inch drivetrain lift. When I swapped in the 5VZ I ended up using the 1 inch engine lift from 4Crawler. This resulted in effectively being a 1 inch body lift as far as the engine placement-to-body relationship is concerned. The upper intake doesn't look like it clears, but it does.
So, you could go with a minimum 1 inch body lift, or go with a hood scoop. If you are leaning toward the 1.5 inch body lift, that would work.
Attached Thumbnails Body Lift for 3.4 swap on 1988 4Runner-dscn0532.jpg   Body Lift for 3.4 swap on 1988 4Runner-dscn0534.jpg   Body Lift for 3.4 swap on 1988 4Runner-dscn0535.jpg
Old Aug 31, 2014 | 06:21 PM
Zorlac's Avatar
Amazing!, Thanks a lot for the pics and the info,
your 4r, looks great
clean 3.4 swap
4crawler is the way
6th Gear
19
Dec 10, 2019 07:31 AM
JF9243176
Oct 8, 2017 04:21 AM
Goddamnboh
3.4 Swaps
12
May 11, 2016 09:22 PM
vasinvictor
Jan 20, 2016 12:39 PM
JF9243176
Jun 24, 2015 04:53 AM
