3.4 swap started
Old May 21, 2010 | 01:11 PM
  #781
mt_goat's Avatar
Originally Posted by bewarethebeast87
Hey sweet rig bra!!! Ive followed your build from the begining but have never posted and Ive got a question since it seems like your the most knowledgeable on the 3.4 swap subject, ive got a 95 pickup that i did a sas with e-lockers and 4.88s F/R and a 3.4 swap on and it runs sweet, i even had a supercharger on it for a while but decided against spending any more money in the speed realm of things, considering i live in california... But my question is how you got your AC idle up to work on your motor, my AC works when moving down the freeway or if i have my RPMS up but it kicks off at idle, my engine is out of an 01' tacoma and im not sure if they use a VSV or if they run it through the IAC to idle up....... Ive been searching through wiring diagrams through TTORRA and i just cant seem to figure it out. Any help would be GREATLY appreciated, ecspecially with summer right around the corner!!!!
I might actually know that one. There is a little control knob or screw for that and its back behind the glove box on my 93 pickup. It sets at what rpm the AC compressor will shut off. Mine is set to minimum and runs fine at idle. I'll try to find a pic of the general area.
Its in this general area:
Old May 21, 2010 | 10:45 PM
  #782
bewarethebeast87's Avatar
I always wondered what that was for!!!!! Thanks man ill have to give that a try tomorrow!!!!
Old May 27, 2010 | 06:25 PM
  #783
thefallman's Avatar
actually im pretty sure the picture that MT GOAT put up is of the A/C cut relay. the part ur loooking for is the a/c Amplifier circuit board and u need to make a little conversion harness so that the 3.4 circuit board will plug in place of the 3.0 board. circuit board is either mounted on top or bottom side of the A/C evap in the cab.
Old May 27, 2010 | 06:27 PM
  #784
thefallman's Avatar
i could be wrong about the pic but thats what that round thing was on mine. also the a/c amplifiers use and send differnt signals 3.0 to 3.4 ive heard of people not having trouble but looking at the diagrams i cant see how.
Old May 28, 2010 | 04:53 AM
  #785
mt_goat's Avatar
I didn't mean the adjustment screw was on the cutoff relay, just that it was in that general area. Also I don't have a 3.4 AC amp on my truck.
Old May 28, 2010 | 11:04 AM
  #786
thefallman's Avatar
hehe okay got ya i figured u knew where it was.
Old May 28, 2010 | 11:19 AM
  #787
mt_goat's Avatar
Well I could be wrong
Old May 28, 2010 | 11:39 PM
  #788
thefallman's Avatar
GRRR DOUBLED IT up
Old May 28, 2010 | 11:41 PM
  #789
thefallman's Avatar
Well Dumb me missed this the first time lol i really should read more carefully
Old Jun 5, 2010 | 08:50 PM
  #790
Toyo4x4's Avatar
Custom aluminum radiators
Whew! What a read!
If you need a custom radiator, these guys might be able to build one. They have a great reputation with the Chevelle forum guys. Pricey? Yes. But they're excellent. Someday I'll get one for my 'Velle.
http://www.alumitechreproductions.com/69.html
Old Jun 6, 2010 | 05:54 AM
  #791
mt_goat's Avatar
Originally Posted by Toyo4x4
Whew! What a read!
Those look sweet
Old Jun 11, 2010 | 12:48 AM
  #792
GBK_2slow's Avatar
If you dont mind, I am planning to do a rebuild on the 3.0 stock engine from a 1991 4x4, I have been researching for ideas and would like to know more about this swap as well. Im not sure if your hometown does SMOG CHECK every so often years to make sure the vehicles are not polluters but if you were to smog this car with the 3.4 engine, would it be able to pass the sniffer and smog test?? I have the 5spd 3.0 and will be considering the 3.4 5spd swap as well, i know it will be a bolt on except the harness but what clutches and flywheels do i use? or are they the same? Im planning to use the 3.4 engine with the stock 3.0 transmission. ANy sub harnesses out there already made? I know you have OSR. Are they any good?
Old Jun 11, 2010 | 03:11 AM
  #793
Lysmachia's Avatar
The wiring harness isn't the only issue with the 3.4 swap GBK, you also have to do a cross-over pipe, move the battery, etc.
This thread/FAQ should help you with your research. Also check all the stickies at the top of the 3.4 swap section...
https://www.yotatech.com/forums/f160...thread-180750/
Old Jun 11, 2010 | 03:45 AM
  #794
mt_goat's Avatar
Originally Posted by GBK_2slow
... but what clutches and flywheels do i use? or are they the same?
My swap was an auto tranny, I don't have a clue on the manual tranny.
There are lots of variables with smog checks, best if you ask your local muffler shop or who ever does the tests. We don't have checks here in OK.
Old Jun 11, 2010 | 07:35 AM
  #795
theMonch's Avatar
It most definetly is not a "bolt-in" there are plenty of little things you will have to alter or fabricate, i.e. power sterring hoses, fuel line hookups, battery location, etc.
With that being said, it probably is one of the "erasier" swaps out there because it usually requires no fabrication to get the motor trans mounted together and in the truck.
There is plenty of info on this in the stickies at the top of the 3.4 section like was mentioned.
To answer your first few questions. You use the 3.4 flywheel, pressure plate and disk and the 3.0 throw-out bearing. (this is not the only way to go, but is the strongest)
There are no "professional" harness makers out there right now. ORS is out of business. depending on where you get your donor 3.4 from, it dosen't have to be too big of a project to do the wiring yourself.
Read...Read...Read. You will be amazed what details you can learn from all of the threads on YT and in other forums.
Good Luck
Old Jun 19, 2010 | 07:11 AM
  #796
syber_kowboy's Avatar
Originally Posted by theMonch
I
Good Luck
X2!!
Old Jun 19, 2010 | 07:16 AM
  #797
Question
Gold star Those instructions just show how to use the 3.0 canister, you'll still need the VSVs and sensor off the 3.4 canister.
Doing this now after better then a year of no Evap. hehe
The issue I've been having from the get go is ?where are the connecting plugs? The 98 T100 harness I have does not have any "extra plugs". I have the canister and the VSVs but no place to hook them up. Am I stoopid or some ting? Is it on a separate harness? I was planning to just make one. Any suggestions?
Old Jun 19, 2010 | 07:33 AM
  #798
mt_goat's Avatar
I don't know about the T100 engine harness but the electrical connectors were on my 2001 Taco engine harness. Where was the stock 3.4 canister on the T100?
Old Jun 19, 2010 | 12:24 PM
  #799
The evap is in basically the same place. Drivers side inner fender. Square box with VSV's attached. The ECU has the wiring for it but the harness does not. I think I will just have to make one. Thanks for the info.
Old Jun 30, 2010 | 05:42 PM
  #800
GBK_2slow's Avatar
thanks guys! Been reading for weeks and weeks now and finding out almost exactly what to do now. I think this task would be quite wasy with very few mods to deal with. Thanks Yotatech for much info. This thread is one of the best threads on this cite!
