3.4 swap!!
3.4 swap!!
I have a 1990 pickup with the 3.0 and just last night I picked up a 97 4runner great running everything except the body is trashed so I'm fixing to do the 3.4 swap into my 90 pickup 4wd 5 spd and I was just going to get everyone's advice for tips and tricks for the swap what you did for the crossover pipe the wiring the ac and everything I'll take any and all advice thanks in advance guys oh and if you bought any after market parts where did you get the my main concern is the dipstick the wiring and the ac thanks guys
Read all the stickies in the 3.4 swap section.
Vasinvictor did a great job of getting the ac figured out, it's a sticky also.
I made my own harness, not that bad plus you'll learn tons about your rig.
If I was to do another 3.4 swap I would do away with the stock cross over, I would join the two banks under the transmission or behind the transfer case
Like JasonYoda said, read through the 3.4 swap section, all the information you'll need is there.
https://www.yotatech.com/forums/f160/
Of particular take a look through these builds,
https://www.yotatech.com/forums/f160...splant-143516/
https://www.yotatech.com/forums/f160...started-82145/ (a lot of the pictures are gone, but the info is still there)
https://www.yotatech.com/forums/f160...4-swap-128285/
https://www.yotatech.com/forums/f160...ex-cab-196823/
and http://www.offroadsolutions.com/tech...fe-conversion/ <-- tons of good info and you can buy a conversion harness from them if you don't want to do it yourself
These guys are good too, I had them do my cross over http://www.toyonlyswaps.com/Home_Page.php
Another question I have is will the ECM and engine work since the truck is a 5spd I've been reading and I've seen a few say it will and some say it won't which one is it thanks guys
Pay the $100 for the correct 5sp ECU, then convert the engine harness to a 5 speed, its not that difficult but takes a little time and a good bit of research to figure out what needs to be done; as another hint, look at the Swap 101 sticky, he's converts a 97 4Runner wiring from auto to 5 speed (or better yet, look at the end of my swap thread for the pinnouts for the conversion harness to mate a 97 5spd to a 91 4Runner).
If you don't want to do that, you can "trick" the ECU to think it's always in Neutral and make it work, but you will ALWAYS have a CEL (check engine light) displayed because the A/T ECU also controls the trans and expects to see signals from it, which your 5sp cannot provide, so the ECU will throw a code. Look around, it's been done, and it's been discussed at length.
You have to do the park/neutral switch, but you also have to remove the auto temp sensor and plug it back into the harness there is a code for that, same with the 3 shift solenoids in the trans.
These will fail due to heat and need replaced with correct resistors to cheat the ecu into thinking they are still there.
If none of this is done you will have 4 obd2 codes throughing ecu into limp mode and 7 mpg! Ask me how I know how.
That being said I'm getting over 20 on the hwy no problem now.
Converting the harness and paying 250+ shipping wasn't going to happen for a 5 spd ecu.
The info is out there some of it is on here but I really had to dig for the type of resistors used.
Good luck and yes its well worth it, the 98 harness and engine is the best IMO!
Flying91
45
Apr 11, 2024 04:39 PM
LosPatosDelSur
23
Mar 12, 2021 03:08 AM
WTB[PacNorWest]: WTB - Tacoma/4runner 3.4 Charcoal canister and igniter
94whiterunner
Jul 12, 2015 07:15 PM
