3.0 Starter in 3.4?
Old Aug 5, 2011 | 06:11 AM
Innocent Fool's Avatar
3.0 Starter in 3.4?
Can I use a 3.0 starter in a 3.4?
3.4 is a 5spd and running the 3.4 flywheel
Old Aug 5, 2011 | 08:27 AM
Ride4Fun's Avatar
Yes, you can use either the 3.0 or 3.4 starters of these swaps. You have to drill the threads out on one or the other - I don't remember which it is, but it will work.
Old Sep 1, 2011 | 01:19 PM
hamish_18's Avatar
Use the 3.0 starter since you are using the 3.0 tranny. 3.4 flywheel will work just fine. If you want to use the 3.4 then you have to drill the bottom bolt hole out on the starter.
Old Sep 3, 2011 | 12:05 AM
anthony1's Avatar
I"m using the 3.0 starter with my swap.....based on the info here.
Old Sep 5, 2011 | 10:08 PM
DeathCougar's Avatar
If you use the 3.0 starter, you need to use the 3.0 flywheel. The flywheel offset if different.
If you use the 3.4 starter, you have to use the 3.4 flywheel
Old Jul 30, 2012 | 04:22 AM
Update
So I went with the 3.0 starter in my 3.4 5spd with 3.4 flywheel and have no issues to report. No grinding, odd sounds problems engaging.
No Mods or drilling necessary.
Looks like it works with no issues.
Straight install
Old Nov 19, 2012 | 07:49 PM
Austin Marr's Avatar
Originally Posted by Innocent Fool
Update
Straight install
I went with the 3.0 starter as well, no issues with my flywheel grinding or any different sounds
Old Mar 13, 2019 | 07:31 AM
jbtvt's Avatar
Pics for searchers: this is an aftermarket TYC out of a '97 3.4
This is a Denso out of a '90 3.0
I didn't get the camera dead in line with the gear end for the Denso either, rushing as I didn't want to burn out the coil, so the difference in throwout is actually a little less than it appears even, possibly the same, certainly within 1/16, at least between these years and brands.
toyotamonster
3.4 Swaps
7
Apr 16, 2020 06:02 PM
Amer
3.4 Swaps
19
Jun 5, 2017 10:43 AM
Valvoman
Aug 8, 2015 03:52 PM
93toyoguy
Aug 2, 2015 07:41 PM
ZONAYODA
Jul 13, 2015 07:17 PM
