Yet Another 4Runner With The Rear Axle Seal Problem
Old Oct 10, 2002 | 02:30 PM
HBoss's Avatar
Took my 4Runner to get the 6-month chasis-lubing and rear-brake adjustments done, and to my dismay I fall victim to the somewhat well-known "do you know your rear axle seal is leaking all over your brake shoes?" problem.
So I have to take it in tomorrow to have them replace it. That's $350 (approx. $220 USD) I didn't want to spend...
Anyhow, for those of you who might have questions as to what caused it, I have no idea. I have no rear diff breather, diff plug is not clogged. I got the rear suspension TSB done & other than Bilstein shocks, it's all stock back there.
Apparently this is quite common on Chevy's as well, from what I hear. How many of you have had this done/fixed?
Old Oct 14, 2002 | 07:34 PM
Adam F's Avatar
I've said this several times in several threads, but have them inspect your axle shaft to see if its not bent. Mine was. I had 3 seals replaced before they figured out it was the axle shaft.
Old Oct 14, 2002 | 09:07 PM
HBoss's Avatar
Thx Adam. Axle seems to be in good shape. The one inner boot that leaked had been replaced before and whoever did it, jammed it in there and did a shabby job, which is probably why it leaked this time.
The guy's who replaced it told me the above and feel that it should have no further problems, because they did it right this time.
We'll see in another 6 months I guess (fingers are crossed).
Old Oct 25, 2002 | 04:35 AM
SLC Punk's Avatar
I feel your pain man!! I just had my axle seals replaced on wed 10/23.... I HOPE this is the last time!!
Old Oct 25, 2002 | 05:04 PM
Adam F's Avatar
Wonder if Toyota will ever release a TSB for this? It's obviously a problem.
6th Gear
19
Dec 10, 2019 07:31 AM
voiddweller
19
May 2, 2016 09:10 PM
DanStew
Jun 29, 2015 10:46 AM
Niameyrider
Jun 25, 2015 05:50 AM
Leonel
Jun 13, 2002 02:42 PM
