Where's the 3.0 fuel pump?
Old May 17, 2005 | 07:14 PM
Del's Avatar
Del
*DISCLAIMER* Even though I try, sometimes I'm blind when it comes to searching**
Ok so I searched and searched but couldn't find any info. My 3.0 is running weird (idle is really low when stopped on an incline, any incline, even my driveway and even stalls sometimes) and my dad thinks it's the fuel pump. I looked but couldn't find it... Someone please tell me where it is!
Thanks,
Daniel
Old May 18, 2005 | 04:56 AM
mt_goat's Avatar
Aren't they all in the gas tank? http://personal.utulsa.edu/~nathan-b...28fuelpump.pdf
Old May 18, 2005 | 06:51 AM
eric-the-red's Avatar
Fuel pump for a 94 is in the gas tank, you have to drop the tank to get to it. And I'm no expert but I thought when fuel pumps were going you usually have problems with hesitation at higher speed, as the pump can't keep up with the demand.
Old May 18, 2005 | 08:02 AM
Marc's Avatar
There might be an access panel under the rear passenger seat to get at the fuel pump.
Old May 18, 2005 | 08:07 AM
Steveh29's Avatar
There is no access panel. You have to drop the tank. Or you can do like my brother did on his 1996 Camaro when it went through it's third fuel pump.... cut your own access hole in the floorboards!
Old May 18, 2005 | 05:54 PM
Blair's Avatar
The access panel is located under the rear passenger seat.
At least, on my '91 it is.
Old May 19, 2005 | 09:10 AM
Steveh29's Avatar
Really? My 95 doesn't have one. If I have to change my fuel pump though I'll certainly cut one.
Old May 19, 2005 | 09:19 AM
braverex's Avatar
Thanks,
Daniel
Hey Dan~
My first thoughts would be to check the spark plugs and do a quick cleaning of the TB. Just a thought before you go through the hassle of messing with the fuel pump since these two can be done very quick and inexpensively...
Old May 19, 2005 | 12:39 PM
Silver_Truck's Avatar
Weird...mine doesn't have one and I have a 91 hmmm...
Old May 19, 2005 | 01:22 PM
mt_goat's Avatar
I think he has a 4runner and you have a pickup, right?
Old May 19, 2005 | 05:41 PM
Blair's Avatar
Right there, under the seat, under that little flap of carpet, there should be another metal flap. Open that up and you're looking at the top of your gas tank. Undo the screws, and you should be looking at your fuel pump and sending unit. At least, on a 4runner you should.
Old May 19, 2005 | 05:54 PM
oh I see now...you have a 4runner, I've got a pickup theres our diff now
Old May 19, 2005 | 05:58 PM
Bigblock's Avatar
check the fuel pressure ,then go from there.
Old May 24, 2005 | 08:18 AM
Del's Avatar
Del
Thanks for the replies everyone. Sorry I wasn't back sooner, I was in Berekely for a friends graduation. I'm guessing from eric-the-red, the fuel pump isn't my problem, since the Runner is fine at high speeds... In fact, we cruised up to Nor Cal (400 miles) in about 6 hours with the AC on and it ran like a champ!
I had the head gasket done a few thousand miles ago, and got a tune up (changed plugs, wires, distributer and adjusted the timing), so I know it's not that. I also noticed last night that it's not restricted to inclines anymore, as it almost died while backing out of a parking lot. I just don't know what's up... My last guess would be the fuel filter since I've had the truck for 60k, and I'm sure the guy who put the original 94k never changed it.
I'll try that and see what happens...
Charecter1
Nov 6, 2023 10:08 AM
sandyota
Feb 4, 2021 11:16 AM
TURBOrunnerNM
Jul 22, 2015 11:01 AM
Fundy Rider
Jul 16, 2015 01:35 AM
Tyler Cunningham
Jul 11, 2015 10:18 AM
