Vacuum Switching Valve Vsv Constantly Switch / Tick When Running? P0441 Please Help!
Old Jun 14, 2005 | 04:54 AM
BOSTON4RUNNER's Avatar
hello,
Had the code P0441 I think it is on a 1997 3.4 liter 4 Runner SR5
for the vacuum switching valve, I put in a new one and it seems to constantly tick when running, I never noticed this before with the other one, perhaps because it was bad
light was out for quite a few days as I disconnected the battery, reset computer
anyway today the light came back on, I opened the hood and could not hear or feel any ticking, switching at the valve like I did the other day when I installed it
anyway, I then physically moved the valve itself, wiggled it, right away starting ticking/switching again like it did the other day....perhaps I have a bad connection and it stopped ticking this morning and set off the engine light? do these work consistently while running, or intermittently? maybe jsut a coincidence that it started working when I touched it?
please advise!
thanks, tim
boston ma
Old Jun 14, 2005 | 09:54 AM
MTL_4runner's Avatar
Keeping in mind that P0441 says "Pressure in charcoal canister does not drop during purge control" and "During purge cut-off, pressure in charcoal canister is very low compared to atmospheric pressure".
If you already replaced the VSV then there are really only 2 other options left:
1) Even though you checked, there is still is a vacum leak in one of the lines
2) The EVAP canister might need to be replaced
Old Jun 14, 2005 | 10:56 AM
I will check the vacuum lines
I am also using a better diagnostic tool that I have here at work
I am a marketing director at a transit authority, and they have some sick fun toys in our bus garage so I am going over in a minute
I guess the usual starting fluid check for vacuum leaks will suffice?
thanks again for the help
also dare I ask how much a canister goes for?
Old Jun 14, 2005 | 11:25 AM
A canister is not cheap at all (in the hundreds $$$$).....try to get a used one if possible.
I would use a hand actuated vacum pump to check for leaks on each line (they are cheap if you don't own one).
Old Jun 14, 2005 | 11:43 AM
first things first, tonight will pull codes right after work, then check vacuum
maybe I can find a used canister...
Old Jun 14, 2005 | 12:23 PM
4Crawler's Avatar
Clean the charcoal cannister. Just need some low pressure conpressed air (about 40 psi) and the instructions in the Factory Service Manual.
Old Jun 14, 2005 | 02:22 PM
I will do that
tonight I am clamping all the vacuum lines, a couple of them in the area of the VSV valve do seem a little loose fitting
I pulled the code, it said P0441 B...is the B part of this code? I am also going to check out the area near the gas, tank, filler neck etc, I hear that a vacuum leak in that area can also cause these codes?
thanks again
tim
Old Jun 14, 2005 | 03:12 PM
just checked all vacuum lines in engine compartment, used soapy water and also starting fluid
i could not find any leaks
also blew very light air through the charcoal canister, does not seem to be any leaks in that either
Old Jun 14, 2005 | 03:25 PM
I will do that
thanks again
tim
You can use the smaller zipties to secure the ends of the hoses once they check out ok to ensure a good seal for vacuum.
Even though this is for a 2003, the system is still almost the same:
http://www.tankota.net/repair/Repair...e/cip0441p.pdf
Most of the time when the VSV is bad it will throw both P0441 AND P0446.
When a vacuum leak is present, you will likely just see a P0441 OR P0446 (may be some exceptions).
You really should get a handheld vacuum pump or at least a vacuum guage to be able to diagnose the problem properly.
Old Jun 14, 2005 | 04:43 PM
Most of the time when the VSV is bad it will throw both P0441 and P0446.
When a vacuum leak is present, you will likely just see a P0441 (may be some exceptions).
i will get a pump and gauge, before going any further
any links to what type of pump i should get?
thanks again
Old Jun 14, 2005 | 06:48 PM
thanks again
You can get a vacuum pump like the one that comes with a brake bleeder:
or at least a simple guage like this:
Old Jun 15, 2005 | 09:50 AM
BADLNDS's Avatar
heres a TSB fix for that problem...hope this helps. I was told the same...start with the VSV valve...then the tubing and lastly the charcoal canister (cause thats the most expensive)
-B
Attached Thumbnails Vacuum Switching Valve Vsv Constantly Switch / Tick When Running? P0441 Please Help!-evap.jpg
Old Jun 15, 2005 | 10:48 AM
badlands
did you find the source of your problem?
if so what was it?
Old Jun 15, 2005 | 11:26 AM
BADLNDS's Avatar
my light stayed off for 3 weeks and then came on again on a hot humid day...I am replacing the VSV valve first next week...I'll keep you posted.
Old Jun 15, 2005 | 11:29 AM
BADLNDS's Avatar
I was trying the not to top off the fuel to see if it was that...I was also told to replace the rubber seal on the gas cap...so i am replacing seal along with VSV valve....that tsb is the repair for that condition...so i will do step at a time...and if all fails...i'll change the canister last (I hope it doesn't go that far?)
-B
Old Jun 15, 2005 | 12:12 PM
im gonna replace the vacuum lines, will likely do this tonight, then will check for vacuum leaks once again as MTL has suggested
if that doesnt do it
i am, maybe i shouldnt but before replacing the canister
i am going to take it out, give it a real hot bath in hot water with palmolive, flush it all out, blow it out with light pressure air
hang it out to dry, i also wonder if there is a spot to drill a drain hole then repair it with body panel adhesive or similar
then re-install it
i have done the same to standard transmissions that were not shifting right, and people would cringe, would re-install throw in synthetic and never had a problem
Old Jun 16, 2005 | 04:38 AM
replaced vacuum lines,,,,and today light came back on
man o man this is going to drive me nuts!
I hope the bath I give the canister will work, but still have to check with a vacuum gauge and pump before I do that...
Old Jun 16, 2005 | 05:32 AM
then re-install it
For the EVAP canister you could try drilling a hole near the bottom and let it drain out any gas that might be in there and then use a self-tapping oil pan bolt with a rubber washer (only do it hand tight with a socket....no ratchet!). There could be 2 complications I can think of when doing this. First, I have no idea how thin the plastic is in this area and where to drill because there might be some structural areas on the canister. Second, you never know how brittle the plastic is or has become over time and it may shatter if you are not careful. Also remember the canister is not empty (usually filled with activated charcoal, but may be another substance which absorbs gas vapors) so whatever material is inside may come pouring out if not careful.
You might also want to take a look at this:
http://aftermarketbusiness.com/after....jsp?id=164723
Old Jun 16, 2005 | 06:25 AM
hey
thanks again for all your help
first i will use the vacuum gauge and pump
check it out
then a very careful drill clean and drain may be in order
i will let you all know how i make out
Old Jun 16, 2005 | 06:47 AM
BADLNDS's Avatar
That was a good article MTL 4runner!
boston..let me know how you made out...I'll keep you posted on my repair. And if you find a way to fix the canister instead of replace it...let me know.
-B
