bleeding brakes
bleeding brakes
can anyone tell me how to blesd the breaks in my 86 4runer. i know the order and i know that you undo the little plug on the calipers and pump the breaks, but im not clea ron it all. can someone give me the oder of steps that i need to do???? do i put more fluid in the resivor before i start? any other hints????thanks
I use a vacuum bleeder for mine, one person is all that is needed:
http://www.jcwhitney.com/autoparts/P...rake%20bleeder
Just start at the driver's side rear, set up the bleeder (vacuum pump-hose-reservoir-hose) and stick the hose on the bleeder, pull a vacuum, crack open the bleeder and pull out fluid until it runs clear. I usually try to flush 4-8 oz. of fluid out per brake, but for manual bleeding just go until the air bubbles come out. Top off the master cylinder as it needs it. By the time you finish, you have flushed out the old brake fluid with about 1 qt. of new stuff.
For 2-person bleeding, see:
http://www.stoptech.com/whitepapers/...rakesright.htm
You need to get one person in the vehicle and another at the brakes. Have the person in the car pump the brakes and hold the pedal down then the person at the brakes will open up the little valve untill all of the air/fluid has came out. Close the valve and repump the brakes and open it again. Keep going through this process untill no air has came out for a couple of cycles. Also keep checking your reservoir to make sure it has fluid in it. If it gets to low you will suck air and have to start all over.
If using the pedal pumping method be very carefull not to press the pedal down too far, you can ruin your o-rings in the master cylinder if you do. Check this out:http://www.gadgetonline.com/BrakeFlu...edal%20method:
Originally Posted by anomaly
AWW DAMMIT, I spent fricky $75 shipped on the Motive one, and I don't see it doing anything better than that one.
Nice thing is the vacuum pump w/ gauge is a useful diagnostic tool by itself. Handy from testing vacuum actuated things on the engine, checking vacuum readings, etc. I like multi-purpose tools
Originally Posted by Jared Ajlouny
20 bucks is just the repair kit....
check out Motive Power Bleeders. I watched it work on my truck and it's fast, efficient and ensures no air in your system if done properly.
http://www.motiveproducts.com/
Troy
Troy
CanRunner
Jul 20, 2015 01:29 PM
