Air Conditioning Quit
Old May 22, 2005 | 05:43 PM
L33T35T 4Runner's Avatar
1995 4runner 3.0 2wd auto
a/c was working perfect yesterday. i get in my truck this morning, nothing. blowing warm. after driving truck for 15 mintes, still warm. i turn the a/c button on and off and the a/c clutch engages and disengages, but still nothing. yes, its on cold and circulation
ideas? questions to help clarify? comments?
Old May 22, 2005 | 08:52 PM
Tacoma Dude's Avatar
Maybe it's time for a recharge?
Old May 22, 2005 | 08:54 PM
rimpainter.com's Avatar
Is the belt still on?
Old May 23, 2005 | 04:53 AM
CynicX's Avatar
i wouldnt think it would be a refrigerant leak if it was working GOOD yesterday. You should have noticed it not cooling as well. Unless somehow you got a huge leak and lost it all at once, possible I guess.
As mentioned I would check the belt. Feel around it while its running see if you can hear if anything odd. Feel the lines too for temp change.
Old May 23, 2005 | 04:09 PM
ya, belt is still on, and when i turn the switch on and off i can hear it engaged and disengage (mainly by the engine rpm's changing). one more note: when i turn the truck off after the A/C switch has been on for a while, there is a hissing sound coming from the passenger side, sounds like a pressure relief or something. ill feel the lines for a temp change.
Old May 23, 2005 | 05:18 PM
CynicX's Avatar
i see that alot in homes A/C systems....the little pressure left is equalizing across the system after it is shut down. Check the pressures maybe it is really low.
Old May 25, 2005 | 11:04 PM
bump.
Old May 28, 2005 | 07:39 AM
4Crawler's Avatar
There is a low pressure cutoff switch located behind the glove box. If that is the cause, a jumper in the connector a tthe switch would make it run, but the real fix would be to have the system topped off with freon.
Old May 29, 2005 | 03:47 AM
Bigblock's Avatar
is your hot water valve stuck open?
Old Jun 1, 2005 | 05:57 PM
turns out i had a small leak in one of the main pipes. battery acid corroded it
88sasturbotoy
Jan 30, 2026 01:57 PM
BeMiceElf
Oct 10, 2015 09:40 PM
Tacoma1313
Aug 17, 2015 05:44 PM
Toyvana
Jul 29, 2015 10:47 PM
terminator
Jul 27, 2015 07:13 PM
