60K maintenance Question
Old Mar 18, 2003 | 05:52 AM
Outkast`'s Avatar
Question 60K maintenance Question
Hey all,
I was wanting to know if the $400 price tag on the 60K maintenance is a rip or fully justifiable? The guy that I called at the dealership rambled off about a dozen or so things that would be done to my runner, and seeing that I’m at work I don’t have time to be at all thorough. Has anyone else had this done and if so do you now deem it worthless or well worth it? Could you have done it yourself? Any information is welcomed.
Thanks,
Outkast`
Old Mar 18, 2003 | 06:41 AM
FattyCBR's Avatar
I'm assuming you mean for a 3rd gen right? If so I had mine done last summer. The only thing I could not do was change the timing belt. So I had them change the timing belt, put all new drrive belts on, and flush the coolant system with Toyota antifreeze. Total cost was around $260.
I changed:
1) All other fluids- tranny, differentials, and T-case
2) New plugs
3) Cleaned throttle body
4) Flushed brake system
I should have greased the drive shafts, but didn't.
Old Mar 18, 2003 | 11:34 AM
EDGE's Avatar
Their was a thread in the 4Runner section titled 60k Tune up, why they did not move that but moved yours is unknown.
I asked my dealer about the 60k service and he told me $470
What have you done up to 60k, they don't need to perform everything listed, this is what I got from my Toyota dealer as to the services they perform, not all my apply to you, read through it and tell them what and what not to do, I copied it out of a booklet so it applies to all Toyota vehicles.
60k Maintenance Schedule
Replace engine oil
Replace oil filter (genuine Toyota filter)
Lubricate suspension
Lubricate all hood & door hinges and latches
Check and replenish fluids
Inspect vehicle for leaks
Perform automatic transmission service (drain and refill)
Adjust brakes and handbrake to factory specs
Inspect brake linings for wear
Adjust belts to correct tension & check wear
Rotate tires (where applicable)
Examine exhaust system for leaks and security
Check front and rear suspension and steering components
Test electrical system
Service battery (fill to level, clean corrosion, coat terminals)
Install BG Service Kit
Reset tire pressure (including spare) examine for wear
Inspect all hoses and clamps
Replace air filter
Inspect throttle body for combustible residue and clean
Test distributor, ignition wires and coil
Replace spark plugs if applicable (non iridium)
Drain coolant and replace for proper protection level and condition
Road test vehicle by Factory Trained Technician
Free one day rental
Hand car wash
Recommended: 4 wheel alignment
Recommended: Timing belt replacement
Recommended: Throttle Plate Service
Recommended: Fuel Induction Service
Recommended: Transmission Flush Service
Recommended: Cooling System Flush Service
Here is the 60K Tune up Thread
https://www.yotatech.com/forums/show...60k+Maintaince
Old Mar 18, 2003 | 12:19 PM
Outkast`'s Avatar
Thumbs up Thanks
Thanks Guys!!!!
I guess I know what I'll be donig this weekend...
Outkast`
Old Mar 22, 2003 | 09:13 AM
AznSky's Avatar
omg, what if you're mechanically illiterate and don't know crap about cars? I think i'm 400 bucks in the hole lol.
Damn I need to learn more about cars.
okamikai
Apr 30, 2018 10:19 PM
Team420
Dec 30, 2015 01:31 PM
AppalachianOffRoader
Aug 11, 2015 01:15 PM
anniesball
Jul 30, 2015 12:14 PM
TURBOrunnerNM
Jul 22, 2015 11:01 AM
