22RE crank, rods trashed
Old Oct 20, 2004 | 01:30 PM
MO Diver's Avatar
Just now getting 22RE short block replaced in my truck ('93 2wd). Apparently the crank was getting oil starved somehow. I never got the oil light on and wasn't ever short of oil.
Dealer says that possibly oil pump was not putting out enough pressure since bearings and channels furthest from oil pump were damaged the most. Oil sensor tested fine. Anyone know of whether there is a problem with a the oil pump pumping enough to keep sensor turned off buy not enough to lubricate engine?
Guess I now know why it's called the idiot light.
Old Oct 20, 2004 | 01:55 PM
SoCal4Running's Avatar
I would immaging the oil weight would make more of a difference than pressures since the other bearings were ok. Or maybe its all relative.
bigjstang
Jun 2, 2025 03:56 PM
ShakinIt2x
Jul 21, 2015 06:20 PM
PlayAwhile
Jul 20, 2015 11:36 AM
redneck17
Jul 17, 2015 07:44 PM
Huntingtruckcletus
Jul 8, 2015 05:26 PM
