Engine Swaps Swapping an engine in your Toy, here is where to learn how
22r to 22re
Old Jan 29, 2016 | 05:11 PM
Stvnred1's Avatar
22r to 22re
I have a 87 pickup with the 22r. Looking to swap to a 22re out of a donor truck. What will I need. Any info is helpful
Old Jan 30, 2016 | 11:52 AM
nbl300's Avatar
are you looking to swap the motors or just the efi parts on the carb motor? if swapping motors youll need computer gas tank exaust manifold talilight wiring harness {contains the wiring for electric fuel pump and all of the wing in the front end of the truck motor harness headlight harness fuse box re engine and everything attatched to it
Old Jan 31, 2016 | 06:42 AM
wyoming9's Avatar
Red face
Just drag the whole truck home you will be glad you did.Plan just how your upgrading the fuel system to the EFI pressures
EFI fuel management ECU engine harness and Injectors.all the sensors
Figure out if your swapping parts or the complete engine.
Then go from there .
Old Jan 31, 2016 | 06:51 AM
Stvnred1's Avatar
I am swapping complete engines. I'm not sure if I wait to swap fuel tanks or go with external pump. What are some opinions?
Old Feb 5, 2016 | 08:42 AM
Corey Burke's Avatar
hey I'm about to swap a 22re out of an 85 into my 82 pickup it's running a 22r with L50 tranny it should just plug right up ?
Old Feb 6, 2016 | 01:33 AM
wyoming9's Avatar
Red face
Depends just what you mean by "plug right up"
Old Feb 7, 2016 | 07:03 AM
I mean it should bolt up to the engine mounts and tranny
Old Feb 7, 2016 | 10:48 AM
wyoming9's Avatar
Red face
Yes that part will go together
Old Apr 6, 2016 | 01:46 PM
Justin85114's Avatar
Hello everybody,I have a 94 toyota 4x4 22re needs a engine would a 89 22r work in my truck? the 89 22r runs good and it's affordable and what I can afford ty everybody for your input .
Old Apr 7, 2016 | 02:57 AM
Terrys87's Avatar
The 89 motor will work. You will have to remove the dish cam that drives the mechanical fuel pump and swap distributors. Add your fuel filter mount on the passenger side and all of your intake and emissions to the motor.
If using a 2wd motor, you will need to swap oil pans and pickup tubes.
yota884huntn2
Apr 17, 2016 04:50 AM
9322rerunner
Dec 1, 2015 12:43 PM
chuckd83
Nov 30, 2015 01:40 PM
roydavis
Nov 12, 2015 07:20 AM
Brandon Mason
Nov 7, 2015 11:47 PM
