4Wheeling 101 Discussion pertaining to the proper use of your off road gear and recovery techniques
is this the right kind of strap?
Old Jan 24, 2010 | 10:06 PM
twitchee2's Avatar
Yesterday i performed my first real recovery in snow, i didnt have the traction to just tow my buddy out so i just yanked. it seemed like it was a very stiff. I assumed the strap would stretch a little when i yanked, do i have the right kind of strap or do i need to get something else?
this is what i have.
http://www.smittybilt.com/product/index/71.htm
Old Jan 24, 2010 | 10:09 PM
AZkid's Avatar
i have had bad luck with stretchy straps,
it snapped right in the middle and came back and wacked the top of my truck, i was lucky it didnt take the back window out,
now i use a strap very similiar to yours
Old Jan 24, 2010 | 10:10 PM
RobD's Avatar
That will work, but it doesn't say anything about having any "give" to it, like a snatch strap does. You have to be careful, because taking a run at it might cause it to fail.
Hit up YouTube for examples of towing fails.
Old Jan 24, 2010 | 10:16 PM
twitchee2's Avatar
thats what i was worried about. what would you suggest
Old Jan 25, 2010 | 12:43 PM
TOYOTA 1's Avatar
http://www.masterpull.com/cpage.cfm?cpid=425
Old Jan 25, 2010 | 04:08 PM
DocWard's Avatar
I posted this on another thread:
I finally pulled my speedstrap out of its bag to pull out a kid in an F-150. I can only say it worked as advertised, and the fact that he didn't have any good attachment points (no hooks or rings) meant that I didn't have to run it through a loop or tie it or anything. Just laced it, pulled, unlaced, and put it away. OK, it sat in my back seat until the snow on it melted and dried, then I looked for dirt, THEN put it away. At any rate, it seems well made and I'm glad I made the choice.
http://redartdev.com/index.php?optio...=130&Itemid=21
Old Jan 25, 2010 | 04:16 PM
RMA's Avatar
RMA
Originally Posted by DocWard
how much was that thing , cant find the price.
Old Jan 25, 2010 | 04:22 PM
MaK92-4RnR's Avatar
for the sake of all of us, and your truck. Dont use a hook related tow strap to pull people out... all it takes is one yank to snap the line and send that hook flying at you at over 100 mph... lol
Old Jan 25, 2010 | 06:22 PM
toyotabull's Avatar
yeah, hook straps and chains hurt when they give. I keep 2 or 3 straps in the toolbox for pulling. Now I have seen people take a car tire and put it between 2 straps to pull people out with a jerk "NOT RECOMENDED"
Old Jan 25, 2010 | 06:52 PM
twitchee2's Avatar
i was not using hooks, had a couple 3/4in shackles on each end. i was just surprised when i assumed i had a recovery strap and it didnt have any give in it. it worked just fine, i got my friend out no prob. I really like those master pull ropes. i have to look into them and start saving.
Old Jan 27, 2010 | 06:15 AM
DocWard's Avatar
I can't remember! Sorry, I'll have to see if I can find the cost and get back with you.
Old Feb 14, 2010 | 08:45 AM
93yotaSR5's Avatar
master pull. brings a whole new level to pullin' it. hahaha
Old Feb 14, 2010 | 09:13 AM
Jacobeo5's Avatar
Found a site decent prices on masterpulls.
http://www.adv4x4.com/matowro.html
Old Feb 18, 2010 | 08:44 AM
DocWard's Avatar
Here is one source for the Speed Strap. It is more expensive than I recall, but I'm still happy with mine.
http://www.teakatrucks.com/Big-Daddy...red-342201.htm
I just pulled a guy over the last weekend, and then ended up getting tugged out of a bad situation myself when I got a little too deep in the snow and a little off camber. The guy that pulled me had a chain already hooked up to his rig and hooked me up. He started pulling and the chain broke, fortunately causing no damage. I pulled my strap out from behind the back seat of my Tundra, laced it up, and he pulled me out. The extra length of mine helped him get some momentum and onto better surface. I couldn't be happier with it.
Old Feb 18, 2010 | 08:55 AM
Irish Death's Avatar
2 straps one spare tire...
Old Feb 18, 2010 | 10:52 AM
poynter's Avatar
I have one of those straps with the metal hooks. If they aren't for recovery what are they good for?
Old Feb 19, 2010 | 04:29 PM
Jacobeo5's Avatar
A good rated tow strap with metal hooks is ok for towing. The only problem with them and the reason most don't have them is because they can be dangerous. While most come with just looped ends that are meant to be used with "D" rings or hooks on the vehicle. the straps that have a hooked attached to them may come loose. If you simply place the hook around a tow point and pull with constent tension no real big problem. but if you start yanking and the strap become loose and taught again that hook may loose what ever good placement it had. Now if the strap is yanked without that hook being properly seated you have a metal that is gonna come flying through your rear window or back at the person your pulling.
Old Feb 19, 2010 | 04:43 PM
xxxtreme22r's Avatar
Just an FYI, most if not all ORV parks requires hook-less/d-ring-less style straps.
Old Nov 1, 2018 | 09:51 AM
Brock Lee's Avatar
I suggest Bubba Rope and synthetic shackles. Get the recovery rope that's appropriate for the weight of your vehicle. (Yes, I know this thread is ages old)
ashamsuddin
17
Jul 22, 2024 03:59 AM
kawazx636
Oct 6, 2021 03:03 PM
live4soccer7
May 11, 2016 06:52 PM
Obmi
Oct 4, 2015 11:30 AM
myotherrideisayoshi
Sep 29, 2015 05:41 AM
