Trial Gear ifs eliminater kit S.A.S help 80s to 81 front solid axle
Old Mar 1, 2009 | 09:45 AM
norcali707@gmail.com's Avatar
I bought the trial gear ifs eliminater kit it says you have to use a 1981 and up front solid axle. Do you guys know what the difference is between 80 and 81? I have a friend who will give me a 1980 sold front axle but my kit says to use 81 and up.
Old Mar 1, 2009 | 10:07 AM
waskillywabbit's Avatar
Main website page says 79-85 SFA.
Install instructions say 81 and up.
Only thing I know that is different is the axle gusseting. Never personally used anything but an 84/85 axle.
Old Mar 1, 2009 | 02:32 PM
86Toyrunna's Avatar
should just be the gusset.. u should be good to go
Old Mar 1, 2009 | 03:28 PM
bigarms23's Avatar
i agree with above
Old Mar 1, 2009 | 06:11 PM
ok so the pumpkin would be in the middle and i cant use the upgrade armor the kit came with ?
Old Mar 1, 2009 | 06:15 PM
No, the gusseting on the bottom of the earlier year model axles is shorter or there is none. The pumpkin is going to be on the passenger side. Diff armor should work. I don't know of anything that won't work with that axle with that kit.
Old Mar 2, 2009 | 10:07 AM
dirtoyboy's Avatar
Some people actually prefer the older style axles (79-81) with no gusset on the bottom...
There's about a quarter to half inch extra ground clearance under the driver side axle tube!
Old Mar 2, 2009 | 11:53 AM
OK well I found a 1985 solid front axle i think im just going to get that for $300 bucks is that a good deal ? its newer so i hope its in better condition. And wabfab I might buy some 5.29 gears from you guys do they hold up well ?
Old Mar 2, 2009 | 11:11 PM
yotaofdoom11's Avatar
5.29 gears hold up great, my roomate has been running them on his SAS 4runner for the last 4 years with aussies and hasnt had a problem yet, at first the small pinion will through off but the strength is there
Old Mar 11, 2009 | 08:40 PM
sweet I might buy some. I have the axle all rebuilt and sanded just needs welded which I had to repair my welder because its been many years sense ive used it.
Old Mar 14, 2009 | 06:41 AM
ScottyC's Avatar
The 79-80 axles have a smaller hub assembly, lug nut base diameter, and rotor design than the 81-85s. So, the reason why TG say they won't work is because their new rotors won't work with the older hub assembly on the 79-80 axles. Lug nuts won't press into the back of the hub/rotor. Although, you could just swap in a later model hub assembly.
Old Mar 14, 2009 | 08:24 AM
neoworm0's Avatar
I second what ScottyC has to say. If you found an 85 though you're good to go. I would say $300 is fair. I don't know about your neck of the woods but those axles are getting hard to find around here. Prices are going up.
Old Mar 16, 2009 | 06:37 PM
netwt12's Avatar
the rotors for the 79 and 80 pickups mount with with 6 bolts not wheel studs and 2 bolts. 79 & 80 axles will need an 81 or so fj40 rotor to get a vented rotor. trail gear doesn't sell a 6 hole rotor.
Old Apr 29, 2009 | 07:54 PM
camarorally68's Avatar
hey guys i got a question i have a 1998 toyota 4runner 2wd i have got some of my 4wd conversion parts but i was wondering these kits you can buy to convert you 4runner to sas. the ones form marlin and trail gear say there for a ---- to a 1995 would they work one my 98 or do i need to get it from somewhere else and if so where from.
mskalmus
May 28, 2017 07:51 AM
MMA_Alex
25
Apr 18, 2017 05:07 AM
ItsJustD
Jul 7, 2015 07:49 AM
Jnkml
Jul 6, 2015 01:20 PM
toyoda8488
Jul 5, 2015 10:18 PM
