Steering Clunk, SAS
Old Jan 18, 2012 | 07:48 PM
stevev88's Avatar
Steering Clunk, SAS
I tried searching but couldnt find anything. I have an 88 toyota p/u, leaf sprung SAS, high steer (hydraulic assist), 37s ect. Recently at full lock and slow speed corners or even if i hit a pot hole at slow speed I get a loud clunk coming from the front end. Also while driving straight and turning the truck from side to side to shake it I can get it to clunk (other than that its relatively smooth). Any help would be appreciated in directing where I should look. Nothing noticeable leaking anywhere, no vibrations or shakes while driving, everything feels tight when I jack it up and feel things.
Thanks very much, still learning lots here so dont always know where to look.
Steve
Old Jan 18, 2012 | 09:47 PM
pyrojoe22's Avatar
u bolts and all shackles bolts are tight?
Old Jan 18, 2012 | 09:55 PM
stevev88's Avatar
Ya everything seems tight there
Old Jan 18, 2012 | 10:51 PM
pyrojoe22's Avatar
What did you set your preload to on your knuckles? Should be at about 15lbs drag with 37's. And did you use equal shims on top and bottom?
Old Jan 31, 2012 | 10:39 PM
eastsideyota's Avatar
do the dana 44s have a pre load setting?
Old Feb 21, 2012 | 11:07 PM
rivercat83's Avatar
Being that I cant determine the exact noise you are hearing, im throwing this out there on a whim I guess. It cant help to check anyways. I had been hearing a strange noise myself sort of how you are explaining, only when turning the steering wheel. Sort of a moderate "clunk". Turns out the small clip that holds the break line to the bracket, behind the shock hoop, had fallen out. Every time I would turn the wheel the break line would slip through the bracket causing the noise. May not solve the problem, but who knows, maybe youre in the same boat I was.
Old Feb 22, 2012 | 05:57 AM
waskillywabbit's Avatar
Pot hole at low speed, check your ubolts with a wrench. Trying to check them by hand is pointless as you aren't going to budge anything.
:wabbit2:
Old Feb 26, 2012 | 11:02 AM
skatemn's Avatar
Jack up the front end and shake your tire side to side to check play in tie rod ends. Get a big pry bar under the tire and check your ball joints. 37's have a tendency to tear these parts up. Also check your clearences on you steering linkage to leaf springs, frame etc...
Old Feb 29, 2012 | 04:19 AM
FourGee6Tee3's Avatar
What leaf spring pack are you using, aftermarket, homemade? If it is the latter I would look to see if your leafs are fanning and the friction between them is causing the "clunks". I give this advice because thats what mine does constantly.
Old Mar 16, 2012 | 06:11 PM
stevev88's Avatar
Thanks Ill check that, appreciate the help
Old Jan 30, 2013 | 07:48 AM
Dave the welder's Avatar
Was the problem ever solved? I'm have the same issue.
Old Mar 14, 2013 | 05:26 PM
Alex Robert Aceto's Avatar
I also have the same problem but I know the problem is the steering hitting the drag link. I just finished my SAS and mounted the front hanger in the correct place... do i need a flat pitman arm? what does that entail? anyone?
runnygirl19
Nov 19, 2015 11:39 PM
RickyD
Oct 2, 2015 07:53 AM
Kylenicoll33
Sep 17, 2015 08:40 AM
potatopants
Sep 15, 2015 06:26 AM
128keaton
Sep 3, 2015 05:09 PM
