Sas front drive shaft
Old May 7, 2009 | 11:38 AM
AiNoKeA_808's Avatar
Sas front drive shaft on a 92 yota
ok I got a 92 Toyota pickup and i can't find any thread talking about where you can get a front drive shaft for the conversion. The only threads I'm finding are saying that you need to get the front drive shaft custom made? Is that the only option I got for the front drive shaft? HELP!
Old May 7, 2009 | 11:57 AM
swapped89's Avatar
Trail-Gear http://trail-gear.com/driveshaft.html
Marlin crawler http://marlincrawler.com/axle/drive-...rive-shaft-kit
Old May 7, 2009 | 11:58 AM
OrRunner's Avatar
http://www.trail-gear.com/driveshaft.html
you can also check with a local machine shop, sometimes they can custom make one for about the same price to fit your truck specs.
Old May 7, 2009 | 06:45 PM
thanks for the sites
Old May 7, 2009 | 06:46 PM
waskillywabbit's Avatar
Any driveshaft shop can make you a new driveshaft because after you SAS your truck your front stock driveshaft will be WAY too short.
Old May 9, 2009 | 04:46 AM
RaginYota's Avatar
In addition to what waskily said, the front IFS cardan joint doesn't have angle for it also. If you don't understand, let me know I will take a picture for you. I still have my front IFS driveshaft. Good luck with your decision, it took me a while to decide.
Jeremy
Old May 9, 2009 | 05:46 AM
Jeremy
Here is an article on modifying the IFS cardan joint:
http://www.4x4wire.com/toyota/tech/cvmod/
Old May 9, 2009 | 10:21 AM
Jeremy
i was told that i would have to extend the driveshaft that i will use. so say if i get a 85 front axle, would it be better to get a brand new drive shaft and have a drive shaft shop to extend it? or is getting a used drive shaft extended just as good and extended a new driveshaft? Can i get that picture too Jeremy?
Old May 9, 2009 | 10:22 AM
thanks for the info
Jun 1, 2021 01:51 PM
lledwod
Aug 30, 2016 01:03 PM
Jnkml
Jul 6, 2015 01:20 PM
karbin
Jul 5, 2015 11:37 PM
toyoda8488
Jul 5, 2015 10:18 PM
