SAS - is this normal for hole in frame at front shackle?
Old May 8, 2009 | 04:13 AM
fordmgt1's Avatar
I used the plasma cutter to cut out the holes for the front shackles, but a stock hole in the frame is right above it. This is where the jigs put the hole though, is this normal? Or do I have a problem? Its and 86 4Runner and a Trail-gear kit. Thanks for the help.
Old May 8, 2009 | 06:06 AM
SteveO's Avatar
Ya might want to put a plate over that to help strengthen the hole you just cut and the hole above it. Just an idea to help strengthen it.
Old May 8, 2009 | 06:10 AM
fordmgt1's Avatar
Thanks, has anyone seen this on a 4Runner? I was looking and found some pics of trucks and I don't think they have a hole there at all.
Old May 8, 2009 | 06:17 AM
gennro's Avatar
Yeah my 1988 truck doesn't have that hole.
Old May 8, 2009 | 06:23 AM
fordmgt1's Avatar
Well, sucks for me, must be a 4runner thing or an 86 thing
Old May 8, 2009 | 06:36 AM
cootees's Avatar
I have that hole on my 90 but when I did my swap it did not hit the hole like that.
Old May 8, 2009 | 06:45 AM
fordmgt1's Avatar
Does it look like i did something wrong? I mean, anywhere you put the template it will hit that hole
Old May 8, 2009 | 06:50 AM
algranger's Avatar
should be fine just weld a plate on there with a hole in it for some strength
Old May 8, 2009 | 12:17 PM
904_runner's Avatar
Mine also had that hole. They are on most newer rigs i think.
Weld the shackle tube where it goes. then take a plate or so and grind it down so it goes over somewhat smoothly and weld that on to brace it up..
Old May 9, 2009 | 09:32 PM
BLKNBLU's Avatar
That's how mine are. Don't worry about it.
Old May 9, 2009 | 10:15 PM
dropzone's Avatar
Fossilized
plate it.
might as well pull the DS off your TC now, the splines are not gonna be long enough for you anyway....
Sep 4, 2015 09:27 AM
crashburnoveride
Aug 28, 2015 09:20 PM
razorman8669
Jul 12, 2015 12:13 PM
smiley52
Jul 11, 2015 05:16 AM
karbin
Jul 5, 2015 11:37 PM
