Is this SAS shackle angle ok??
Old May 9, 2009 | 05:30 PM
fordmgt1's Avatar
I finally got my axle sitting under my truck, but I am kind of worried about the shackle angle. Its a Trail-Gear SAS kit and the instructions said the angle should be slightly back and will eventually settle to 20 deg. back. I have a 4" front spring and they recommended to move the spring hanger forward 3/4", I moved it just a little over 1/2". My angle is very slightly back, when I bounce up and down on the truck it moves more back. Does the angle look ok in the pics? Any help would be appreciated. Thanks.
Old May 9, 2009 | 06:12 PM
TOYOTA 1's Avatar
Ive seen worse lol.. but it could be better.. when the springs settle it will get a lil better.
hows your tire to firewall clearance? maybe you could slide the front hanger back a 1/4 inch.
Old May 9, 2009 | 06:37 PM
waskillywabbit's Avatar
I always mount my front spring hanger flush and never had a problem with shackle angle.
Old May 9, 2009 | 07:04 PM
Plumbrbob's Avatar
i would move it imo
Old May 9, 2009 | 07:44 PM
shaw_j's Avatar
Go for a hard wheel, and see where it sits once it is settled
It may not be the best right now, but will settle
Old May 9, 2009 | 08:22 PM
scuba's Avatar
I've never done a sas, Never owned a solid axle vehicle.
But from my 2 years of learning experience on yotas, a vertical shackle angle is bad.
Old May 10, 2009 | 07:26 AM
yoterr's Avatar
the instructions to move it 3/4 of an inch forward are for a v6 truck from the photos im pretty sure you have a 22r, move the front hanger flush with the frame and you should be fine
Old May 10, 2009 | 08:52 AM
fordmgt1's Avatar
Well... I think I'm gonna bit the bullet and move it flush with the frame, the hard thing for me is that the front cross member is bent and angled toward the pass. side, so its a lot of measuring and doesn't look the best b/c the hanger will be straight and and the crossmember is not.
Old May 10, 2009 | 08:59 AM
Sounds like your truck has been wrecked. You should get the frame straightened before welding on the new front spring hanger or everything will be out of whack.
Old May 10, 2009 | 10:02 AM
bruzer's Avatar
wheel it hard and get about 500 mile or so under it and they should settle. My were verticle as well when I did mine and they are starting to kick back a little. But mine have taken a bit longer since the law says I cant drive mine on the street.
Old May 10, 2009 | 10:03 AM
scuba's Avatar
x2 !!!!!!
Old May 10, 2009 | 02:33 PM
fordmgt1's Avatar
The frame doesn't seem straight, but I've been 85 mph when I got it and it tracked very well... I had a friend follow me to look at the rear to make sure it was tracking straight, and it was. I got the spring hanger in there straight to the frame rails, so I just hope for the best. I will not exceed 55 mph in it after the build, I will just be going to the local off road park. Thanks for the advice though.
Old May 10, 2009 | 03:16 PM
fordmgt1's Avatar
oh, and that was 85 going down hill, lol
Old May 12, 2009 | 07:31 PM
ChickN's Avatar
Talking
it took one trip before my 5" tG springs settled....but i had no front shocks so....not sure if that makes a difference...but i did one 1/8 mile rock garden and i noticed that they settled at least and inch and a half...but this is my angle and i know that its is not the best! bust she still droops and stuffs pretty good!
this is on a first gen
live4soccer7
May 11, 2016 06:52 PM
ktm192k
Oct 1, 2015 08:47 AM
oldblue
Sep 28, 2015 04:07 PM
Toys4parts
Sep 26, 2015 01:56 PM
Project90
Sep 24, 2015 11:40 PM
