SAS almost done.. finally
Old Jul 11, 2007 | 09:01 PM
seafarinman's Avatar
A pic of my SAS. Almost done. Still need to address tierod/draglink/pitman clearance issues when suspension is compressed. Need to install shock hoops, add some leaves to front and rear suspension, weld in rear shock mounts, fab square tube driveshaft... still a lot of work to do.
Old Jul 12, 2007 | 12:42 AM
Kaleb's Avatar
Right on. Welcome to the club!
Old Jul 12, 2007 | 01:10 PM
Specs:
1980 Toyota axle rebuilt
CV Unlimited Newfield Birfs
Stock axles
FJ60 rotors
Sky's "Toyota" axle top gusset
T-G Brake plate eliminator
T-G Rockring wiper plates
V6 third with 4.10 gears
Marlin Crawler knuckleball gussets
AllPro large differential guard
Marlin Crawler SAS hanger kit welded 1.75" forward of stock
89 4Runner rears/mazda rear hybrid 6 leaf pack(needs more leaves going to add some 89-95 top 3 leaves chopped to length and possibly 1.5" lift rear AAL) with Rancho spring centerpins
T-G High Steer
Sky's Pitman Arm Adaptor (coming off when I move steering box and use T-G flat pitman arm)
T-G 12 inch shock hoops
ProComp ES3000 12" shocks
T-G u-bolt flip kit
(Probably need degree shim to point diff toward t-case)
Hope to have it done this weekend (unlikely) or before next weekend (more likely)
Old Jul 16, 2007 | 09:41 AM
Death Wobble on new SAS rig
I got pretty much everything mounted up. shocks are on, just need to move the steering box and fab up front driveshaft now. Rear height matches the front too. I took it for a test drive and at 30 mph there begins the "Death Wobble" and the truck is uncontrollable and I need to stop and turn around and take it home. Checked wheel bearings, tierod/draglink etc. Found that the front spring bushings are kinda loose. Don't have a steering stabilizer mounted yet. Anyone know where I can get the replacement bushings for the rears up front springs? The original bushing hole was too small to use the bolts in the M-C hanger so I burned them out and used mazda bushings.
Old Jul 16, 2007 | 10:33 AM
AxleIke's Avatar
Death wobble is a symptom of caster missalignment.
Steering stabalizer will be a bandaid, and likely not eliminate it completely.
Get some shims, and either set caster yourself or have a shop do it. Get rid of the problem completely.
Old Jul 17, 2007 | 08:03 AM
Well I pulled a leaf out of the front spring pack and installed some 6* shims in its place. I was able to test drive the truck. Got to this one curve on the road and it made it without the DW. I was driving down the road at a higher speed 45mph and it was doing great, and then turned down another road and there it goes again. Had to slow way down, and drove it home with no further problems. I am going to install my old steering stabilizer and call it good I think.
Old Jul 19, 2007 | 08:27 PM
I got the steering stabilizer installed today. Fabricated and installed the new square tube (85 CV/94 yoke) after drilling out the flange on the transfercase output to accept the 85 CV flange. Tomorrow I will start on relocating my steering box...once relocated I will call it done until the engine rebuild and gears.
Old Jul 28, 2007 | 07:49 PM
Steering box relocated and flat pitman arm installed. Now all I need to do is get the engine rebuilt and diffs regeared front locker and install, and some 37's.
Yotav6power
16
Mar 4, 2016 07:45 AM
Corvoid
Dec 11, 2015 11:21 AM
RickyD
Oct 2, 2015 07:53 AM
Flying91
Sep 10, 2015 03:41 PM
ErikZ1220
Sep 10, 2015 04:53 AM
