My SAS project progress
Old Jul 21, 2007 | 02:57 PM
chimmike's Avatar
Welp, spent yesterday afternoon trying to unbolt the crap before I got wise and just decided to cut.
Spent the morning cutting and grinding, got the passenger side ground fully and a coat of primer. As my buddy got there and started removing the upper a-arm, a thunderstorm moved in (I'd been working outside the garage in the driveway), and stayed around for a while. Well, after the lightning stopped, the rain let up a little bit, and we figured, what the hell. So, got everything cut off the driver's side, now I just have to grind it down in the morning. Once that's done, I'll be finishing up welding the shackle sleeves in place, and hang the springs. It's coming along well now!
Sorry no pics, the rain put a damper on things.
Notes to others doing SAS:
1) Without a torch, use a sawzall and 4.5" grinder.
2) Buy at least 5 long bi-metal sawzall blades, and at least 3 short ones
3) Buy at least 5 cutting wheels
4) Buy at least 4 grinding wheels
5) use the BFH (sledge) when necessary. Don't be afraid!
6) Pry bars will be very useful. Buy many.
7) Get a set of tall jackstands from Pep boys or something. Cost me $36 and they should be o.k. height even after the SAS.
Old Jul 21, 2007 | 03:06 PM
dirtoyboy's Avatar
i just used about 40 cut off wheels, BFH and a cold chisel lol
Old Jul 21, 2007 | 04:33 PM
waskillywabbit's Avatar
Old Jul 21, 2007 | 06:09 PM
chimmike's Avatar
Man, the Sawzall cut through that stuff like butter. That much was great
I'll get pics tomorrow after I finish grinding.
Old Jul 23, 2007 | 05:28 AM
chimmike's Avatar
Question on shackle angle. I know I should know this, and I think I do, but I want to check and make sure.
Looking at the passenger side of the vehicle...... spring going to the right from the shackle....it's supposed to be like / under load, right? Right now, under no load, it's sitting like \ .
I'm assuming it'll switch under load?
Thanks guys
Old Jul 23, 2007 | 07:09 AM
4Runner92sr5's Avatar
pictures would greatly help!!!!
Old Jul 23, 2007 | 07:14 AM
44Runner's Avatar
wow dude. You guys need to get torches, lol. Ask for one for christmas!
Old Jul 23, 2007 | 07:45 AM
chimmike's Avatar
I got one, just didn't have time to fill the tanks.
The sawzall ended up working better IMO, and some finishing touches with the cutoff wheel cut grinding to a minimum.
I didn't cut off the inner IFS diff mounts yet. I can do that later. They aren't interfering with anything and won't with the SFA, so that's not a priority yet.
Old Jul 23, 2007 | 07:49 AM
Old Jul 23, 2007 | 08:54 AM
chimmike's Avatar
I'm at work now. I'll post some later tonight if I have time. I'm gonna try to hang the axle even without one side knuckle completed yet.
Old Jul 23, 2007 | 04:30 PM
chimmike's Avatar
Pics!
clicky
clicky
clicky
clicky
clicky
clicky
clicky
clicky
sorry the pics are so big, too lazy to resize, hence the hotlinking lol
Old Jul 23, 2007 | 05:06 PM
1st link doesn't work.
The rest look nice. Having fun yet?
Sure does look like there is a gap between the OEM and SAS front hanger? I would put some more weld on it as some of those welds look suspect IMO.
Old Jul 24, 2007 | 04:17 AM
chimmike's Avatar
I haven't gusseted the front hanger yet. I'm going to do that and stick some bar between the gap to weld in place as well for some extra structural support.
Old Jul 24, 2007 | 01:14 PM
44Runner's Avatar
I agree
Old Jul 24, 2007 | 01:29 PM
yotasavg's Avatar
i'm definately following this one! nice work. did you decide to go leafs or stay coils in the rear?
Old Jul 24, 2007 | 05:10 PM
chimmike's Avatar
well, just waiting on the hub nut kit to come in tomorrow, and i should be able to hang the axle (so long as I get some damn help, I can't lift that thing by myself!)
Old Jul 25, 2007 | 05:22 PM
chimmike's Avatar
hung the axle today, regardless of UPS's dumb asses not shipping something OVERNIGHT on time.....
click on meeeeeeeeeee
the full weight isn't on the springs yet, hence why the shackles aren't all the way back.
Old Jul 25, 2007 | 05:31 PM
Aaronb's Avatar
looks like the shackle angle should be good when you get a load on it.
Old Jul 25, 2007 | 05:41 PM
chimmike's Avatar
yeah. The Trail Gear kit has been pretty good to me. They got every part, and they're all brand new, clean, and pretty
Anyone have any tips for removing the stock Pitman?
Old Jul 25, 2007 | 06:07 PM
44Runner's Avatar
Take the nut off, duh
are you using a pitman arm puller? if not get one.
you can lube it up with some PB blaster and let soke
but basically tighten puller and tap with a hammer should do it. If not liberal heat with a torch on the arm combined with the above methods is a sure fire way to get it off....
