Help!! Please.... Toyota solid axle bent???
Old 02-28-2010, 11:05 AM
dantlm15's Avatar
Exclamation Help!! Please.... Toyota solid axle bent???
So i built my truck up about a year ago and long story short after about a dozen trail rides my camber is off!! I did cut and spin the knuckles to change pinion angle. I tore down the axle and had a very hard time getting the axle shafts out. the axle seals were ovaled. It is a 85 axle so a stock gusset with a added trailgear gusset. so if it did bend it must have been at the very end. I really could use some help do not want to have to find another axle housing. SO CAN ANYONE HELP!? I can post pictues later this week. But does anyone work on this kind of thing? went to local driveshaft shops with no success. any info would be appreciated!!!
Old 02-28-2010, 12:48 PM
waskillywabbit's Avatar
If you didn't go slow when you welded stuff up or welded with the diff in you bent it welding on it.
bigjstang
08-25-2021 12:41 AM
MMA_Alex
25
04-18-2017 05:07 AM
ItsJustD
07-07-2015 07:49 AM
toyoda8488
07-05-2015 10:18 PM
Quick Reply: Help!! Please.... Toyota solid axle bent???
