toyota front axle question
Old Mar 2, 2010 | 04:54 PM
Joshua4507's Avatar
why is there a spring pearch on the botom of the passenger side toyota axle ? why is it there ? and should I cut it off?
Old Mar 2, 2010 | 05:05 PM
Joshua4507's Avatar
may be just to keep the U- bolts straight?
Old Mar 2, 2010 | 05:19 PM
dropzone's Avatar
Fossilized
i think that you might be right...might have to deal with the curve of the differential housing...
Old Mar 2, 2010 | 06:46 PM
4Crawler's Avatar
The stock u-bolts run up and over the springs and there is a plate down below where the nuts screw onto the bolts. The extra bottom perch on the passenger is to allow that bottom plate to sit flat next to the curve of the differential hosing:
Old Mar 2, 2010 | 06:50 PM
Joshua4507's Avatar
thanks 4Crawler
GreenLion
Jun 7, 2021 10:49 AM
6th Gear
19
Dec 10, 2019 07:31 AM
Yoda
Jul 7, 2002 08:10 AM
