Help!! Please.... Toyota solid axle bent???
So i built my truck up about a year ago and long story short after about a dozen trail rides my camber is off!! I did cut and spin the knuckles to change pinion angle. I tore down the axle and had a very hard time getting the axle shafts out. the axle seals were ovaled. It is a 85 axle so a stock gusset with a added trailgear gusset. so if it did bend it must have been at the very end. I really could use some help do not want to have to find another axle housing. SO CAN ANYONE HELP!? I can post pictues later this week. But does anyone work on this kind of thing? went to local driveshaft shops with no success. any info would be appreciated!!!
If you didn't go slow when you welded stuff up or welded with the diff in you bent it welding on it.
:guitar: |
