birfield question
Old Jul 13, 2010 | 02:37 PM
89mailman's Avatar
birfield question
Im doing a knuckle rebuild and was about to put the drivers side birfield back in when I realized the rotating joint gets stuck really easy, as if its rusted. its packed with grease, and I guess the joint has had its fair share of abuse from the past years (axle is out of an '83). my question is am I going to have to replace the birfield or is there maintenance I could do to prevent its stubbornness? thanks
Old Jul 13, 2010 | 05:12 PM
4Crawler's Avatar
Well, you might try cleaning the grease out all the way and them either inspect it intact or disassemble the joint and see what is going on. Might be some grit inside or may be something else wrong, but at least you should be able to see what is up.
Old Jul 13, 2010 | 05:15 PM
waskillywabbit's Avatar
www.ncttora.com/fsm
FSM has birfield info, disassembly and reassembly.
Old Jul 13, 2010 | 07:12 PM
89mailman's Avatar
thank you both
Old Jul 13, 2010 | 11:15 PM
Lysmachia's Avatar
And really the killer solution is to just upgrade to longfields... That was one of the best upgrades I ever did!
lectric80
Aug 11, 2015 12:02 AM
makemusic116
Aug 2, 2015 05:23 PM
makemusic116
Aug 2, 2015 04:40 AM
TJWilly
Jul 31, 2015 02:05 PM
4Runnin2000
Jul 29, 2015 06:09 PM
