Argghhh!!! Another bent axle housing discovered too late! Can it be saved?
I am trying to get this SAS done, but for the second time now I think I have wasted time with a bent axle.
The first housing I started with got all the way painted and was installing the pass side birfield when I noticed that the housing was bent back on the short side...
Into the junk pile it went, along with nice solid steering stops and a trailgear front diff guard.
SO.....
I bought this housing for $40 of CL, and now I believe it is bent upwards on the driver's side now.
I can lift the axle up to center in housing, but its normal resting place is down about 2mm at the axle seal location.
I still have a nice Ballistic upper truss, which is SOOOO much nicer in fit and design then the TG truss, but I don't want to waste it. My hope is I can find a way to flex it straight and then weld on the upper truss.
Thoughts?
SO.....
Thoughts?
Bobby Long can fix these for you. He's located in Graham
Link to his posting on NW wheelers: http://www.nw-wheelers.com/forum/showthread.php?t=53053
Link says he charges $100.00 to fix.
Longfieldsuperaxles.com
ORDER LINE 360-893-0235
TECH LINE 253-847-8254 OPEN 24 HOURS
I'm going to check out Longfield and see if he can straighten it... I am tempted to weld up the upper truss first and then bring it to him so I know it is PERFECTLY straight.
I can't afford to spend $750 for an axle housing at the moment, regardless of how good it might be. One other reason I don't want to go with a new TG housing is that they are 3" wider then the stock housing, and i am planning on using IFS hubs so I can have slip-off rotors. If I use a Rock Assault housing it will be 6" wider!
Well, scratch the Longfield plan. He is no longer offering that service...
Does anyone know of anyone in the Snohomish county area that can straighten this? It seems like a pretty simple operation to me, but I don't have one of those great big steel welding tables where you could chain down the axle and start tweeking it....
Do machine shops do this?
and rock assault axles from trail gear. Both look pretty beef, more or less the same thing.
I believe Dave from Davez Off Road will straighten it. Give him a call. Shipping may nix the whole deal though.
http://www.davezoffroadperformance.com/
It's hard to tell from the picture how bent the housing really is (the axle is just resting/drooped), as good as our EcoSeals they are not the answer to a bent axle housing -- rather they are the answer to improperly shimmed knuckles.
BigMike
BigMike
Basically I was saying put it together and see if it works before spending a lot on trying to fix an axle that may not be bent all that much.
It's bent, no question about that...
Pretty sure you can cut a relief notch on the top of the axle, then weld a small truss on the bottom of the axle to shrink the metal on the bottom, thus un-bending your knuckle.
then simpky re-weld up the top..
tried to find a writeup, but our search function is pretty terrible.
SO.....
Thoughts?
SO.....
Thoughts?
James
Thank you for the tip. If the shop I found can't straighten it, I will Try this method. Sounds like a good last-chance idea.
This is the type of information I was hoping for rather then the usual second-guessing.
I understand that fact and agree completely. It may in fact not be bent that much. I think it may just be the axle resting. Without the proper tool it'd be hard for someone to say for a fact the axle housing was bent.
if you turned the housing upside down, the axle would be in the same position it's in right now - pressed against the edge of the oil seal recess. If i pull on the axle shaft, i can pull it to almost reach the exact center of the housing, but it will return to it's "rest" position up against the oil seal...
see page 2 of this thread on how Dave's Off road straightened an axle
jasonty
41
Dec 23, 2018 01:00 PM
polo451
13
Nov 20, 2016 07:49 PM
