alignment after SAS?
Old Aug 13, 2007 | 02:35 AM
HAVOC's Avatar
I was just looking at some SAS threads. How do you align a truck that had IFS if all the alignment cams were removed with the rest of the stuff? I'm sure it's probably in the instructions, but I'm just curious.
Old Aug 13, 2007 | 04:50 AM
xcmountain80's Avatar
Well for a trail rig and a method we used while at Tellico for a trail fix . Grab a tape measure and measure the inside distance of the front and the rear of the tire. Yes I know sounds like it wont work but it does.
Aaron
Old Aug 13, 2007 | 04:58 AM
seafarinman's Avatar
Solid axles only have a toe-in and caster angle adjustment. I had to install a 6* shim on my spring pack to get the caster in the correct range of 5*-7* because I was getting some bad death wobble. The toe-in adjustment is just the way that XCmountain80 said. You should have anywhere from 0-1/4" toe-in (tires pointed inward in front).
Old Aug 13, 2007 | 10:29 AM
4Crawler's Avatar
Here is how I align mine:
- http://www.4crawler.com/4x4/CheapTri...html#Alignment
Old Oct 17, 2007 | 07:35 PM
derrik86's Avatar
alignment shop
couldnt u just align it of have it aligned at on a alignment rack but align it to the specs of whatever vehicle it came off of ?
Old Oct 17, 2007 | 07:57 PM
ozziesironmanoffroad's Avatar
unless it was the same EXACT vehicle, with the EXACT weight, just SAS and not IFS, then no, since that vehicle would be heavier. for example, ive heard of people taking ford axles and putting them on a yota, and then trying to align them to the ford. doesnt work that way. alignments have to be done to the car that is being worked on, no exceptions that i know of.
Old Oct 17, 2007 | 07:59 PM
Tofer's Avatar
Sponsor
you have more research to do......
ladybugRC
458
Aug 21, 2020 10:41 AM
JookUpVandetti
Sep 30, 2015 08:58 AM
voiddweller
Sep 28, 2015 11:21 PM
Toys4parts
Sep 26, 2015 01:56 PM
Project90
Sep 24, 2015 11:40 PM
