ABS on the fritZ! HELP!!!!
Old 12-20-2010, 11:08 AM
blake.nemitz's Avatar
hey guys i have a 95 4runner 3vze and sas. yesterday while driving home when i push on the brake it feels a little stiffer and every seccond i feel the abs pulse in my toe while aplying pressure, you know the errr, errr, errr, i push harder to slow down and it feels like its pushing back and then all of the sudden the pedal pushes down alot easier and the drums lock up and i come to a hard stop. any ideas? it was fine three days ago now its all on the fritz!! no cel's
could it be bad proportioning bad abs controller? never had any brake problems except when i got it four years ago the abs has never worked and now i guess it does
Old 12-20-2010, 11:16 AM
waskillywabbit's Avatar
On the 95 SAS I did back last April he totally removed all the ABS stuff in the engine bay after we removed it from the axles. Just straight brakes.
:wabbit2:
Old 12-20-2010, 01:39 PM
GonOvr's Avatar
Well more than likely your sensor on your rear axle is bad and your bulb could be burned out. Also the light might not even come one because the ABS is actually working, just not when its supposed to.
IF you want to keep the ABS.
Problem 1 Pull rear sensor out of diff and check it for metal shavings, the sensor is magnetized slightly and catches the fine metal shavings from gears and bearing wear. Those shavings get caught up between the ABS ring and sensor making the ABS think that the rear end is locked up which engages the ABS motor.
Problem 2 Sensor, ring gear, or ECM is bad, inspect the ring gear for cracks, chips, or any damage, replace as needed. ECM failure is rare but still could be the cause. Find a donor truck or a "willing buddy" who you can pull parts off to test and find out what the problem is.
If you want to toss the ABS, Easiest way is pull the ABS fuse or unplug the ABS ECM (inside dash above glove box). You can also delete the ABS motor with new power steering lines bypassing ABS motor and bypassing the brake lines that go to the ABS motor. If you have any questions let me know.
Old 12-21-2010, 08:24 AM
ill try unplugging ecm and fuse, i could care less if abs works i would rather get rid of it all but im going up to the mountains this weekend and in colorado we have a ton of snow so i would be nice to have normal brakes. and besides abs is for pussies ive driven in treacherous weather my entire life with normal brakes and if you dont know how to use your brakes and drive without abs do us all a favor california drivers and stay home. THANKS GONOVER FOR THE ADVICE!!
Old 12-21-2010, 10:15 AM
just pulled fuse ill let you all know
Old 12-23-2010, 04:03 AM
GonOvr's Avatar
Hope it works out man. Just realized your just north of me, I live in Fountain right now.
Old 12-23-2010, 04:58 AM
pulled the fuse and it workes fine, thank god heading up to the mountains holla!!
Old 12-23-2010, 05:30 AM
I'd remove all that ABS stuff if you are not going to use it. Cleans up the engine bay.
:wabbit2:
Old 12-23-2010, 08:48 AM
yea just gotta get motivated, ill probably take it all off when i do the diesel swap
Old 02-11-2011, 07:18 AM
riddarunner's Avatar
You might have a bad wheel bearing. I ahd the same issue on my 05 taco and i also had to pull the fuses just to drive around and not make the abs trip all the time, new bearing and the problem went away. A friend explained it to be as the wheelbearing vibrating and making the abs think the wheel is slipping.
JimiJams
09-28-2015 06:14 PM
BimmerSage
09-17-2015 11:48 PM
BimmerSage
New York
09-17-2015 05:21 PM
matt1833
09-16-2015 07:11 AM
zz_denis
09-06-2015 03:43 PM
Quick Reply: ABS on the fritZ! HELP!!!!
