Off Road Trip Planning, Expeditions, Trips, & Events Discussion pertaining to scheduling trail runs and outings
WATTORA - Naches Pass Trail 07/31
Old Jul 18, 2004 | 09:33 AM
WATRD's Avatar
YotaTechies are welcome to attend...
Details and RSVP are at; http://www.wattora.com/EventDetails.asp?ID=65
This is by far my favorite run of the year... A fun trail with great views.
Old Jul 18, 2004 | 11:35 PM
WSU4runner's Avatar
Sounds like a lot of fun. I just emailed you with some questions
Old Jul 19, 2004 | 08:51 AM
WATRD's Avatar
Cool. It will be nice to see some folks from YotaTech along for the ride. I replied to your mail, let me know if I can be of further assistance.
Old Jul 19, 2004 | 02:04 PM
KevyWevy's Avatar
hmmmm i might be able to get work off. im assuming since it doesn't say anything about it, lockers aren't required right? just double checking to make sure. hmmm it looked like a lot of fun last year...
Old Jul 19, 2004 | 02:23 PM
Shane's Avatar
Lockers are not required, tho' without one there are a couple spots that may pose a challenge.
Old Jul 19, 2004 | 02:26 PM
GRNTACO's Avatar
Lockers aren't required and it's a great to run to attend. You should try to make it you'll really enjoy it.
Old Jul 19, 2004 | 02:35 PM
midiwall's Avatar
Yeup... it's a REALLY nice run through there. If it stays dry, you won't have a problem getting through it at all. If it gets a bit wet, then it'll get some pucker going.
I just put up a thread about the mini run that Ben hosted last weekend. There's a link to pics in there:
https://www.yotatech.com/forums/f15/wa-lil-naches-naches-7-17-04-a-36970/
(ummm, a moving house probably won't be included in your scenery on the 31st)
Old Jul 19, 2004 | 03:48 PM
WATRD's Avatar
Lockers are technically NOT required as such, but keep in mind that there aren't many bypasses. It's not like the hill at Tinkham where you can just give up.
You will be able to do the vast majority of the trail unassisted if it's dry, but some of the hill climbs are pretty loose, even when dry. You will need to balance your tendancy to be pretty light on the skinny pedal with the fact that you MUST continue.
Folks, I mentioned it in the run description, but I will say it again. You MUST have *REAL* front and rear tow points on this run. Period. If you can't get up a hill and don't have tow points, we might still pull you up, but the damage is on you.
Old Jul 19, 2004 | 04:11 PM
midiwall's Avatar
Now that I've been there, I can echo another side of this.
Outside of there not being many bypasses to obstacles, there aren't many places to pull off the trail - and turning around isn't really an option. There are bail-out points in the way of "traditional" FS roads along the way that will lead you out - but they're not an option without a good map or a guide.
If you need to make multiple passes at something, then you have to keep a calm head since you will _have_ to continue on. That can be tough when there's traffic behind you from another group.
Old Jul 19, 2004 | 04:23 PM
WATRD's Avatar
<There are bail-out points in the way of "traditional" FS roads along the way that will lead you out - but they're not an option without a good map or a guide.>
Having explored those roads over the past few years, I would ammend that to SOME of them will lead you out... There's an amazing number of dead ends that spur off the Naches. Some of the roads are fun and go places, others just go up a few hundred yards and end. You can get out that way, but the trick is knowing where
Last year while FS70 was closed on the West end of the trail, after the better part of two months, I found a series of roads and trails that punched through into Government Meadows.
What Mark said about there not being too many places to get over is true. The trail can be crowded, so sometimes you have to set your mind to getting through a section and just do it. I have seen rigs have problems with the hill climbs, especially going East to West and large groups stack up behind them to jeer... not pretty...
Old Jul 19, 2004 | 10:48 PM
WSU4runner's Avatar
This talk about lockers is kind of scary. I don't have one, but I may still come.
Old Jul 20, 2004 | 06:15 AM
Shane's Avatar
Don't let it scare you away from running this trail. There'll be plenty of support to get you through safely, just take your time when negotiating the tight areas and you'll get through without any damage other than possibly a little NW pinstriping.
I've run it many many times with open diffs, IFS, and 33" BFG ATs with not too much difficulty.
Old Jul 20, 2004 | 06:58 AM
GRNTACO's Avatar
Oh yeah! I ran it when my truck was stock (31's, open diffs) east to west and west to east with no problems.
Old Jul 20, 2004 | 09:49 AM
midiwall's Avatar
You'll do fine... I only had my rear locker engaded for one spot last weekend and I really didn't need it. As dry as it'll be, it'll be a breeze for you.
Plus, the folks that will be out with you are all great people - you'll have plenty of help and encouragement.
"Just do it" as the saying goes.
Old Jul 20, 2004 | 05:19 PM
Ken's Avatar
Ken
Looking forward to trying out my new sliders! (Thanks for the help Ben!)
Naches is one of my favorite trails
Old Jul 20, 2004 | 07:30 PM
GRNTACO's Avatar
You're welcome!
I see l you RSVP'd so see you on the 31st.
Old Jul 20, 2004 | 09:50 PM
KevyWevy's Avatar
I WANNA GO!!! but i can't get off work. stupid work. but starting in agust i'll have all weekend off every weekend!!!! i guess its just one day too late.
Old Jul 20, 2004 | 10:35 PM
WSU4runner's Avatar
Ok guys you talked me into it As long as I can get work off I will be out there.
Old Jul 21, 2004 | 04:35 PM
KevyWevy's Avatar
uh oh, kevin might of been able to get saturday off since "CAN'T" work over time from what i've been told from my boss, so i'll have half a day off and hopefully saturday as well!! hopefully i'll know by tomorrow afternoon!!
Old Jul 21, 2004 | 09:44 PM
WSU4runner's Avatar
Good luck It'll be nice to see you out there.
