Off Road Trip Planning, Expeditions, Trips, & Events Discussion pertaining to scheduling trail runs and outings
SE4RJ3 May 11-14, 2006 at Tellico
Old May 7, 2006 | 07:09 PM
  #1141
Stump1883's Avatar
Originally Posted by frty6&amp
Dual cases are officially in my truck. driveshafts are being dropped off at the shop tomorrow. Now only 999,999 other things to finish by Wed.
This trip is going to be awesome.
Wow that's super ambitious, can't wait to see your rig, I have always wanted to actually see dual cases perform, now there's at least 2 on this trip. Can't wait, I can't get out of Greensboro fast enough.
Old May 7, 2006 | 07:29 PM
  #1142
waskillywabbit's Avatar
Looking forward to it Mike.
Old May 8, 2006 | 03:50 AM
  #1143
bamachem's Avatar
twin sticks are the schiznit. fo-reel-do.
steve's 4-banger-of-fury was in super-slow-motion when in low-low-first gear.
Old May 8, 2006 | 04:43 AM
  #1144
Doc279's Avatar
I'll be camping at Tellico by Thursday afternoon.
Old May 8, 2006 | 05:00 AM
  #1145
seaflea's Avatar
We hope to be there Thursday eavening around 5. may not be wheeling the rig though as it needs a front drive shaft.
Iwll see this morning if I can get one by Wednesday.
Old May 8, 2006 | 05:16 AM
  #1146
zman2day's Avatar
Do you need one? You are welcome to my spare if needed...but it maybe too long unless you snuck in a extra case. I think its Flange to flange 25in compressed and 42 inch extended but I will have to double check this afternoon. It is the rectangle flange size on each end(not the square or the small bolt pattern.)
I'm anticipating being there on Wednesday night. Anyone else getting there early?
Old May 8, 2006 | 05:22 AM
  #1147
seaflea's Avatar
Sweet. I need one that is 30" static and 27 compressed. So it may work.
Pmed you
thanks!
Old May 8, 2006 | 05:23 AM
  #1148
sschaefer3's Avatar
Keep in mind that was the Marlin Ultimate, 3 stock cases. I don't know if these guys are that low.
I probably used the 100 to 1 a few times which is just the first case down and the back in high.
New stuff is opposite, 4.7 in the front versus the back on old junk.
That will screw me up on the buggie for sure a few times.
Old May 8, 2006 | 05:27 AM
  #1149
bamachem's Avatar
ahhhh... 3 cases???
but two sticks... i'm confused...
Old May 8, 2006 | 05:57 AM
  #1150
sschaefer3's Avatar
ahhhh... 3 cases???
The front case has a 4.7 gear in it. Imagine two stock cases in one. The rear has the newer low range gear which is like 2.56 and not like 2.28 like the olders cases.
Old May 8, 2006 | 06:16 AM
  #1151
bamachem's Avatar
ok, 3-cases, front is "set" and doesn't shift. 2nd case is a stock case that' either "hi" or "low" and rear case is 2.56 and selectable for 2hi, 4hi and 4lo, correct...
wow. that is low.
Old May 8, 2006 | 07:00 AM
  #1152
sschaefer3's Avatar
wow. that is low.
No, the front shifts: 1 to 1 - N - Double Low
The rear is the same J pattern as everyone else's and activated the 4WD.
You drove this truck........
Old May 8, 2006 | 11:30 AM
  #1153
Stump1883's Avatar
Old May 8, 2006 | 11:44 AM
  #1154
bamachem's Avatar
yeah, once. i flopped the front stick into low and let off the clutch (rear stick was in 4hi IIRC - so that's why it was crawling so slow!). i haven't looked into getting a crawler yet, so i'm not all that in tune with how they're set up.
ok... two cases, front has a 4.7 for a "Double Low" ratio, rear is stock- mostly.
front = 1:1, N, or Double Low
rear = stock J pattern, but with a lower gear ratio
now i think i'm on the same planet...
me > < you
Old May 8, 2006 | 12:57 PM
  #1155
justinh's Avatar
me > < you
It took me awhile to realize that he was referring to the 4.7 case as "two" and then the other one as "one".
Someone, either Marlin or Inchworm built one back in the day that actually had 2 cases, I am not sure if it was just for show or what though.
Old May 8, 2006 | 01:55 PM
  #1156
DH6twinotter's Avatar
1985 4Runner--you got a PM. I can pick up a tire if you need me to. No problem at all. I'll probably have to strap it down on the roof if it's bigger than a 31". Sounds like it is.
Scott and Will--I'll PM you all my cell number just in case something happens and we can't meet up at the Fudruckers (sp?) place.
I got my electrical buggers fixed, so no more ploblems with that. Now for an oil change, new spark plugs and a wash, and I'm ready to go.
Old May 8, 2006 | 02:09 PM
  #1157
1985 4Runner's Avatar
Thanks DH6twinotter,
Turn out the tire is in Boone & Andy is going to grab it & transport for me. So I should be good to go with the tire, but looking for a 15x12 or 15x14 wheel now. I am looking hard.
Sliders get welded on tonight, then shocks...
Old May 8, 2006 | 02:16 PM
  #1158
If you find a wheel here in Charlotte, I'll be glad to pack it along for you.
Old May 8, 2006 | 04:27 PM
  #1159
seaflea's Avatar
Thanks for the cell #. PMed you back with mine.
Old May 8, 2006 | 05:29 PM
  #1160
sschaefer3's Avatar
PM'd you with my favorite flavor of eatable underwear.
