Off Road Trip Planning, Expeditions, Trips, & Events Discussion pertaining to scheduling trail runs and outings
Imogene Pass
Old Aug 23, 2004 | 07:56 PM
Scary Mc's Avatar
Imogene Pass
How difficult is Imogene Pass in comparison to Engineer Pass. I've got a bone stock 4x4 '04 Taco.
Thanks~ Scary
Old Aug 23, 2004 | 07:59 PM
fish's Avatar
Thanks~ Scary
Hiya bonehead!
Old Aug 23, 2004 | 08:01 PM
Scary Mc's Avatar
Originally Posted by fish
Hiya bonehead!
Sweet mother of Gawd, I can't friggen escape!
How was Ouray? I was tendin' to family matters in Tejas.
Old Aug 23, 2004 | 08:46 PM
Darren's Avatar
Imogene is on par with Engineer. I rate it a hard 4, easy 5.
Old Aug 23, 2004 | 08:48 PM
FirstToy's Avatar
I have heard that the rating is changing so what does a hard 4 or easy 5 mean?
Old Aug 23, 2004 | 08:50 PM
Scary Mc's Avatar
Yeah, I though Engineer was pretty easy in the stocker..... No scares or anything....
Old Aug 23, 2004 | 08:57 PM
SkyRat's Avatar
Imogene is way tougher than Engineer if it is wet. There are a few pretty steep ups there, while Engineer has a few more rocky areas (though not really technical). The fear factor is the biggest difference. There are a few places on Imogene that are sheer drop off shelf sections. Not really tough, they just make you thankful you have a narrow Yota instead of a Full Sized Anything.
Old Aug 23, 2004 | 09:07 PM
Darren's Avatar
CO uses the 10-scale, which has been around since 33's were king. It does not take into account extreme trails where tube junk is basically required, and there have been no talks to replace it. It's not like there's an official committee that works with this anyway. I believe folks in CA use a mix of both the 5 and 10-scales. They're all subjective and can always use some tweaking in their definitions and requirements, but they still provide a general summary of what you can expect to see.
So, what do I mean by a hard 4, easy 5? Imogene Pass!
Old Aug 23, 2004 | 09:14 PM
FirstToy's Avatar
Dang Darren, you can be a politician. I'm dizzy!
Old Aug 24, 2004 | 06:28 AM
crawler#976's Avatar
trail ratings are so subjective-
Chris Villareal has done a really nice job of catagorizing ratings by vehicle size/weight. While it is heavily biased towards AZ's rock crawling trails, it still does a good job for general wheelin' too.
http://www.azrockcrawler.com/_images...ailrating.html
Based on Chris's system, and breaking it down just a little more w/ a half point in between #'s, the Colorado mountain pass roads/trails probably rate a 2.0 to 2.5 - a match w/ the Colorado system of 1 to 10 ratings of 4 to 5.
At lower elevation, we generally run 2.5 rated stuff in 2x4 w/ a rear locker only. From my limited wheeling at elevations above 10000' in AZ, and NM, I needed low range to make enough power to climb any steep grades. It will be interesting to see how the 22RE does at over 12,600' next month! We rented a 2003 Jeep TJ last year in CO, and the 4.0L was noticably sluggish when crossing the Continental Divide- and it had at least double the HP and torque I do.......
Old Aug 24, 2004 | 06:37 AM
Scary Mc's Avatar
I might wait for a lift and tires before I hit Imogene then. It's just sooooooo close....
FWIW my '04 Taco had no noticeable loss of power at 12,000+ feet this weekend.
Thanks for all the info~
bryan34w
12
Sep 30, 2015 02:50 PM
Toys4parts
Sep 26, 2015 01:56 PM
taraf
Sep 25, 2015 02:57 PM
Boomer8404
Sep 24, 2015 01:12 PM
Boomer8404
Sep 10, 2015 09:01 AM
