A Trac/E locker hack (FJ Cruiser)
#42
Co-Founder/Administrator
What did you use for a tap?
I still have not bought any, as I have not found any of the T taps like Alex used.
I have a PM into a tech on the forum here too so perhaps he can find out from Toyota if they are going to take care of us older '07 FJs like they are the newer ones coming off the line.
#43
i had some laying around that came with the bumper when i bought it , im sure radio shack or most stereo stores will have them. i dont think your local napa will have them though.
try harbor freight , them seem to have some of the odd ball stuff.
i have an extra , let me know if you need it , i can mail it to you .
you can do the same with a inline splice ( which is all it really is, with a spade hook up) by making a little short lead with spade conectors off it too.
airrikk17
airrikk17
#44
Corey, I have been talking with one of the mechanics at the dealership where I bought my FJ trying to figure out what Toyota did in the post Nov. vehicles to get the ATRAC and rear locker to work together. After two months of reasearch, he finally noticed that the ECU part number changed. The best he can tell, a flash will not do the trick. It will take a new ECU which is pretty pricey. So, I guess I will be doing the no cut hack.
#46
Thanks Hog.
One guy who did do the hack is seeing a problem now.
He did the hack in the cab, not under the hood like I had planned.
I still have not undertaken this mod, as I want to wiat and see if Toyota does anything.
Doubtful, but I want to see if there are any long term ill effects doing it this way.
#49
As far as I know, no Tacomas have A-Trac.
It is exclusive to FJs only.
Tacomas have Trac, that is different, and for 2WD which the FJ also has.
But put the FJ into 4low, then you have A Trac if you sprang for the package or paid $60 for the switch and installed it, as long as you have the rear locker.
If you have A-Trac, you will see a switch called A-Trac next to the rear locker one.
#50
(the FJC is based on the 4Runner V6 drivetrain). 4th Gen 4Runners do not offer the E-locker though.
#51
A-TRAC, Auto LSD, DAC, HSA.
There are VERY few tacomas with A-TRAC. In the PNW the only configuration you can get it in is the DC SB TRD offroad with JBL.. which I have.
#52
Read your explanation over on TTORA
http://www.ttora.com/forum/showthrea...981#post785981
Learn something new everyday.
#53
#54
From: Nashville TN. I can help you if you're close BUT NOBODY CAN HELP YOU IF YOU DON'T FILL YOUR LOCATION IN!
Vehicle skid control works with pitch and yaw sensors to get the vehicle back in shape, right before, or right after it gets out of shape...
Uses the brakes on one side, or one wheel.. whatever the computer tells the booster.
Stupid A-Trac... Advanced Traction Control, power brakes the front axle to split the power evenly and in the event of a spin-out applies MORE brakes to the slipping wheel... I've see it in person and it looked like it halted a lot of progress, but it might have been the driver.
Power brake the axle at all times... smart
Works almost reverse of Traction Control. There are no brakes applied to the axle. Wheel slip sensed via wheel speed sensor, and it applies the brakes to the slipping wheel...
Whatever.. I'll never own one... Too reliant on too many systems...
BTW, ARB's or TRD's trick differential speed biased traction control systems into thinking the car is going in a straight line. This means NO DRAG from brake biasing traction control systems...
Also, IMO Tru Track or Torsen the front and USE traction control and forget that A-Crap stuff... You'll get a TON more capability out of it.
H1's use that type of system. Traction Control and gear driven limited slips. Once the other speed sensor bumps, it releases the braking force on that side. No drag on the axle at all. Once it slips TC grabs the slipping wheel and the limited slip works way more efficiently.
TheBFA
Feb 15, 2020 06:55 AM
83yotastockR
11
Nov 10, 2015 06:54 AM
4runnerFireman
Sep 29, 2015 06:24 AM
Toys4parts
Sep 26, 2015 01:56 PM
FS[PacNorWest]: 1987 4Runner SAS, 22RE, 5Spd, Dual Cases, etc
toyotasaurus
Sep 24, 2015 03:30 PM
