possible front suspension problem
I hit a small pot hole the other day where just my right side hit the hole. Now my steering is off and I have a bad pull to the right. No tire or wheel damage. What gives? Do we have weak suspensions?
Originally Posted by SLC97SR5
threw out the alignment...that hard jolt moved the adjusting cams?
Originally Posted by gapguy
It's possible that an alignment cam wasn't tight enough when it was built.
Either way, you get a FREE Alignment during your first 12month/12k mile "adjustment period".
especially if its been done allready in this week, take it back, theres no reason for it to fall out,
i took the advice of some one else here and take a torque wrench with me when getting it from the shop, both times, ive had a couple that were not torqued all the way. In addition to having peace of mind that they are tightened correctly, I have also, both times, received a 1/2 off the next time im in for showing them as I tighten to spec
turns out it was the tires. They swapped both front tires with each other, and now it pulls to left, and steering wheel moved with it. It only happens when the tire gets hot.
Jun 1, 2021 01:51 PM
Sep 4, 2015 09:27 AM
Vargntucson
Jul 4, 2015 12:15 PM
