93-98 T100s All T100 trucks
question about Intake silencer removal mod for the 96-97 3.4L...
Old Apr 26, 2010 | 12:00 AM
hartzog69's Avatar
Question question about Intake silencer removal mod for the 96-97 3.4L...
https://www.yotatech.com/forums/f130...engines-74837/
I have been wanting to do this mod for quite some time, and have been trying to look it over, maybe its just from a lack of sleep as ive been busy, but im confused as to why you need a 1.5" pvc cap, a 1"pvc cap, and also a .5" pvc cap, whats the deal with this?
Old Apr 26, 2010 | 12:23 AM
Elton's Avatar
ehh once you remove the black box's gonna have to cover the holes
Old Apr 26, 2010 | 01:42 AM
hartzog69's Avatar
yes, i have looked closer at that post, and i see it has more than one hole, however, on my 1996 T100 has only one black box further up on the intake towards the TB, it is totally different than any of the intake tubes i can find on here that bob has done the ISR mod to, i will try to get pics today of my intake, and maybe a few measurements as to how i will do this mod to my 1996 T100 3.4L V6....I AM CONFUSEDDD ON THIS ONE
Old May 1, 2010 | 04:49 PM
FW-739's Avatar
I recently put on this air intake kit on my T100 very good price and it helps with the new bigger tires.
http://cgi.ebay.com/ebaymotors/1995-...Q5fAccessories
Old May 9, 2010 | 01:52 PM
becaron's Avatar
dude, just remove the silencer boxes, and plug them with whatever size cap you need. Drill, tap, and thread in some brass barbs to hook up the hoses and you should be good. It isn't rocket science.
Old May 13, 2010 | 03:32 PM
Kookadala's Avatar
Originally Posted by becaron
dude, It isn't rocket science.
Hahahahaha, that's great. Maybe he doesn't know how to turn a wrench. Some folks need more help then others.
IIRC, there is only one cap needed for the side of the box, the other ends connect to the large intake pipe. There is a small hose that needs to attach to the side cap for vacuum purposes.
Old May 19, 2010 | 08:39 AM
becaron's Avatar
Yeah I haven't looked mine over in a while. I think mine has two boxes. The large one, and a small one that has a couple vacuum connections to it.
Old May 23, 2010 | 03:53 AM
Matanic's Avatar
Better description for the T100.
http://www.toyotanation.com/forum/sh...d.php?t=340208
Old Jun 7, 2010 | 05:20 PM
WhiteT's Avatar
um question... by doing this mod what exactly is being accomplished?
Old Jun 10, 2010 | 08:29 AM
Zuke79's Avatar
To make more intake noise...
Old Jun 10, 2010 | 10:31 AM
okie81's Avatar
x2, and cleans up the engine compartment a little
Old Jun 10, 2010 | 02:51 PM
Kookadala's Avatar
IIRC, this mod is supposed to reduce turbulent flow through the air intake pipe and provide increased laminar flow to the TBI, thereby producing more power. I did this mod way back when and did not notice any difference, but its good to do if you want to start doing mods to your truck. Start with the air box mod and the next thing you know your doing a SAS!
Old Jun 10, 2010 | 07:50 PM
stockwell45's Avatar
Do it along with the deckplate mod, I saw a 2 mpg increase in mine
Old Jun 10, 2010 | 07:55 PM
rimpainter.com's Avatar
It improves throttle response slightly and increases intake noise, as mentioned. With the deckplate mod open and all silencers removed, it will rattle your sinuses at WOT and 5K RPM, at least in normally aspirated configurations. With the SC'r it's a different story.
kazuya2416
Apr 5, 2024 02:17 AM
Doug4320
Mar 24, 2018 10:11 PM
tj884Rdlx
Aug 28, 2015 12:04 PM
icentropy
Jul 11, 2015 07:21 AM
Nickdigg
Jul 7, 2015 06:04 AM
