93-98 T100s All T100 trucks
Fan bearing blows up
Old Sep 10, 2006 | 07:19 PM
BigA's Avatar
I was doing some hill climbs today in my T. Everything was going well and fine. And on one hill I was climbing up and I almost got to the top when I heard a loud pop and I instantly lost powersteering. As it turns out the fan bearing can bust loose and send it into the radiator. And when that happens the shoud is torn apart, the front of my motor is scarred, the hoses are junk, the alternator and power steering are useless and the entire front of the engine compartment is fubarred. I will try to get some pics tomorrow evening.
Drew
Old Sep 10, 2006 | 08:10 PM
jct61765's Avatar
WOW
Old Sep 10, 2006 | 08:47 PM
Froggy93's Avatar
Ouch. That sucks. I feel bad for you. good luck on the repair
Old Sep 11, 2006 | 04:33 AM
BigA's Avatar
Well I got some pictures of the carnage. I forgot to get one of the radiator.
I think this is going to be expensive to fix.
Drew
Old Sep 11, 2006 | 08:35 PM
elnido's Avatar
sorry that happened. Can anyone comment on what should be done to avoid that?
Old Sep 11, 2006 | 09:07 PM
DeathCougar's Avatar
yea...that amazing Toyota Fan Support design. thought they woulda fixed that with the 5vz but no dice.
BTW people, if that thing is making noise, REPLACE IT or this happens.
At least it didn't take out your hood or anything else majorly.
Old Sep 11, 2006 | 09:09 PM
Elton's Avatar
im thinking the high mileage and wheeling may of played a roll in it failing
Old Sep 12, 2006 | 05:51 AM
BigA's Avatar
That bearing never made any noise. It still turns freely with no problems. I think it was a mix of high miles and a lot of abuse. Luckily I found a used one and a cam cover for a hundred bucks from a friend. I should have it running a few days.
Drew
Old Sep 12, 2006 | 07:03 AM
BigA's Avatar
Also it did dent the hood. But I really don't care. I talked to a Yota mechanic and he said he had never seen that before. So I have no idea what happened.
Drew
Old Sep 12, 2006 | 10:38 PM
What about the other parts, where are you gettin em from?
Old Sep 13, 2006 | 04:49 AM
BigA's Avatar
I get parts though a supplier called Worldpac. They are factory Toyota quality without the cost . The old T should be completely fixed by Thursday. It does drive right now. I just dont have any fan, a small pin hole in the radiator, and no powersteering (no belt for it).
Drew
PS you really can't tell from the radiator picture, but the entire radiator is bowed forward in the center about a half inch.
Old Sep 14, 2006 | 05:11 PM
Greasygreg's Avatar
Big A, can you tell us exactly what broke first?Because i see your fan ,clutch,and pulleys all broke off from the cover.Is it like there is a bearing pressed into that cover that bears the load from belt tension and turning all the accessories? Ive got 200k on my 95' and it pops a little when its cold.
Old Sep 14, 2006 | 06:33 PM
BigA's Avatar
I believe that the first thing that broke was the fan bracket. It started to break and fatigued the aluminum. The bearing itself was fine. I heard it could be from tweaking the mount when changing the timing belt, or the fan clutch staying engaged (thats what happened to me). When that broke off the fan clutch assembly went into the radiator. That in turn took out the radiator, shroud, fan blades, cam covers, positive battery post, belts, upper radiator hoses and denting the hood. But I got it all back together this afternoon. It total for all of the parts came too $450. Not too bad for the amount of damage. Plus it was probably time for a new radiator. Now its time to take the bed off and cut the frame down, add gears and a front locker, and take it to Tellico.
Drew
shalom
Sep 8, 2015 10:02 PM
Kreedy1
Sep 8, 2015 06:33 PM
128keaton
Sep 3, 2015 05:09 PM
markf1
Sep 3, 2015 01:23 AM
Peevedkitten
11
Aug 31, 2015 06:57 PM
