General Electrical & Lighting Related Topics Ask here for electrical, wiring, and lighting info for your rig that could apply to all years
no blinkers, reverse, or park light! help!
Old Dec 14, 2011 | 10:03 AM
94Beater's Avatar
i recently bought a 94 excab and the only problems im having are these lights. the bulbs seem ok and the fuses are ok, any ideas? Thanks
the blinkers dont work on the dash either
Old Dec 22, 2011 | 06:59 AM
AreOhhEnn's Avatar
Do the hazard lights work? The hazard switch is tied into the turn signal circuit on a lot of cars? Was there any work done before all this happened? I'm damned good at diagnosing electrical issues but I'll need more info.
Old Dec 22, 2011 | 07:20 AM
Leviticus6432's Avatar
I doubt he is gonna come back man, thats his only post and it was like a week ago...
Old Dec 22, 2011 | 07:23 AM
94Beater's Avatar
No they don't. The switch sticks for the hazards. No other work has been done that I know of.
Old Dec 23, 2011 | 07:53 PM
94Beater's Avatar
I did a little more checking on the hazard switch I believe it is bad could this be my problem. If not I'm thinking maybe the switch on the column next. Hope that's not it. I have no voltage going to the blinker relay under the dash but I do have voltage to the hazard switch
Old Jan 22, 2012 | 11:54 AM
93NMyota's Avatar
yes if the hazards aren't connected or the switch is bad the signals will not work. this circuit has 2 fuses, one under the hood labeled "haz-horn" 15A and another inside labeled "turn" 10A. check for power at the hazard switch. blue/white (has-horn fuse) should always have power and green/black (turn fuse) only with the switch in ignition position. Let me know if this helps!
Old Jan 22, 2012 | 11:55 AM
93NMyota's Avatar
also check your turn signal flasher
Old Jan 22, 2012 | 11:59 AM
94Beater's Avatar
It was the hazard switch thanks for the help guys!
Old Jan 22, 2012 | 12:03 PM
93NMyota's Avatar
Anytime, let me know if you need help with any other electrical issues
the1998sr5
15
Jul 14, 2020 08:35 PM
ghostmoney
Jan 28, 2018 11:42 AM
AkitaDog
Sep 1, 2015 08:05 AM
mengquis
Jul 13, 2015 10:39 AM
madxman21
Jul 9, 2015 10:26 AM
