General Electrical & Lighting Related Topics Ask here for electrical, wiring, and lighting info for your rig that could apply to all years
Nice headlights
Old Dec 25, 2005 | 08:51 AM
arjan's Avatar
I see what you are saying, the highbeam indicator is actually running through the lowbeam filaments in highbeam mode. The relay coil will have a higher resistance, and then the highbeam indicator will not or hardly show.
Thanks for the headsup, I now noticed the diagram on your website. I just can't believe how Toyota could run the total current through their dinky switch in the cab.
VW also does this, but I opened up a mark IV headlight switch and they have very heavy contacts with strong springs. That I can live with.
The diagram makes total sense, I was just wondering where to get the male & female plugs for the headlights to make the whole thing plug & play.
No offense to your items Roger, but I also like to put stuff like that together and I have the majority of the parts laying around.
Old Dec 25, 2005 | 10:21 AM
4Crawler's Avatar
Yep, VW has some of the same issues, I upgraded my '82 VW with a similar headlight harness and got similar results:
- http://www.4crawler.com/Diesel/Cheap...#WiringHarness
On my A1, the big problem is that the headlight switch is no longer available from VW, so if it burns out, you have to hope you can find a better switch at a junkyard. The relays take about 98% of the current load off of the switch, so it should prolong it's lifetime.
For the connectors, you might be able to find some at a good auto parts store, or just splice into the existing wiring.
Old Dec 26, 2005 | 04:55 PM
Sequoia'd's Avatar
+1 for Roger's harness. I saw a 2.5 volt increase at the headlights. Brought my 80-100's alive.
Bill
Old Mar 10, 2006 | 10:26 AM
97Limited's Avatar
I also noticed that the DRL's do burn out all aftermarket bulbs within a year or so!!
kawazx636
Oct 6, 2021 03:03 PM
4banginRunner
Nov 13, 2015 05:23 AM
Davebarbier
Nov 3, 2015 03:28 PM
mreagen
Oct 5, 2015 04:27 PM
JPV
Sep 28, 2015 03:15 PM
