General Electrical & Lighting Related Topics Ask here for electrical, wiring, and lighting info for your rig that could apply to all years
Installed two power outlets
Old Jul 10, 2010 | 07:35 AM
irab88's Avatar
i did this for my fog lights. works great
(the two circles are the outlets)
Old Jul 10, 2010 | 07:41 AM
irab88's Avatar
Originally Posted by scuba
It would take an hour to add a relay.
i did mine in about 20 mins.
Old Aug 16, 2012 | 10:38 AM
AZTOYOTA's Avatar
Been over two years since install. No fires. Works great. Used daily.
Old Aug 16, 2012 | 11:12 AM
RAD4Runner's Avatar
No Need for Relay For This Apolication
I agree with scope103.
You gotta understand your application before adding parts and throwing dollars at anything. Typically, those outlets are for personal electronics (You don't need a relay for your iPad, do you?), rated for NO MORE than 110 OR 120WATTS (Look at factory-installed ones. Does the lighter outlet require a relay?).
Just know and be sure of the capacity of your switch, wire gauge & length & outlet, pick right fuse for that. Then label your outlet for corresponding wattage rating.
IF you want to run lights that draw more than that, you should not plug it into these outlets; you power it from relays directly powered by battery and near the battery.
Old Aug 16, 2012 | 12:27 PM
  #25
Philbert's Avatar
This is a great thread, thanks for all the info guys.
Old Aug 16, 2012 | 12:51 PM
  #26
mt_goat's Avatar
I don't see the point of switching or adding a relay to any power plugs, mine are hot all the time.
steve miller
Oct 10, 2015 01:40 AM
tj884Rdlx
Aug 28, 2015 12:04 PM
luckypig44
Jul 19, 2015 11:25 AM
mlavery85
Jul 12, 2015 10:33 AM
skoti89
Jul 8, 2015 12:05 AM
