General Electrical & Lighting Related Topics Ask here for electrical, wiring, and lighting info for your rig that could apply to all years
A/C relay?
Old Aug 21, 2006 | 06:21 AM
DixieJoker's Avatar
A/C relay?
Where can I find an A/C relay on a '87 4runner 22re? The comp. clutch only comes on if I attach the wire from it to 12V. I tried jumping the low pressure switch and it did not work. wiring diagram shows a A/C cut relay but does not say where it is.....Thanks in advance...
Old Aug 22, 2006 | 06:02 AM
DixieJoker's Avatar
o.k. then.....I guess nobody ever needed to find the A/C relay
Old Aug 22, 2006 | 09:05 AM
PirateFins's Avatar
On my 92 it is on the top of the valve cover. Should have 2 vacum lines comming off of it. One of them going to the AC idle up adjustment screw. Look for a big white (cold be black) plastic screw on the drivers side of the valve cover and follow the vacum lines to the VSV for AC.
you can do a search on here and find 9 million post about AC alot of them with pics. Search is your friend
Old Aug 22, 2006 | 11:41 AM
DixieJoker's Avatar
Ok I never really found the relay but I did fix the A/C. I was behing the glove box tracking wires and I saw the plug to the A/C amplifier was unplugged. I plugged it in and nothing happened. The 4runner was idling a little low so I turned the knob on the A/C amplifier counter clockwise until compressor kicked on. I then idled the RPM up under the hood. Now I just need a vac. and refill.....Thanks
Old Aug 23, 2006 | 12:29 PM
4Crawler's Avatar
A/C relay is in the center of the dash, passenger side of the center console.
Old Jul 4, 2010 | 05:50 PM
wristpin's Avatar
I also have an 87 4runner and my a/c won't come on at all, can someone tell me where the low pressure switch is, that sounds like a good next step. The fuses that I can find look good but I havent been able to locate the one in the center of the dash yet. The light comes on in the switch. Thanks for any ideas you might have.
Old Jul 5, 2010 | 12:08 PM
4Crawler's Avatar
See below:
- http://www.4crawler.com/4x4/CheapTri...ne_Pix/20.html
Old Jul 8, 2010 | 07:54 AM
Volcom's Avatar
How many amps is the stock Toyota 22RE AC relay? I need to add a relay for my OBA project and was curious what size to use. Also, I wanted to wire it up so it only can be turned on when the ignition is on.
What would be the easiest way to wire this with a switch in the cab to turn the compressor on & off?
Old Jul 8, 2010 | 06:29 PM
wristpin's Avatar
Thanks 4Crawler, that is exactly what I needed. I just came across this thing, its in great shape but I have some of the odds and ends to fix.
Old Apr 12, 2025 | 01:11 PM
srvndo's Avatar
Thanks
im naming my kids after you, this fixed my ac
Badlander
Oct 10, 2015 08:05 PM
bradahman
Oct 1, 2015 09:24 AM
bryan34w
12
Sep 30, 2015 02:50 PM
beltcutter
Sep 30, 2015 06:14 AM
JPV
Sep 28, 2015 03:15 PM
