General Electrical & Lighting Related Topics Ask here for electrical, wiring, and lighting info for your rig that could apply to all years
broken wire igniter connector
Old Dec 27, 2018 | 10:12 AM
Gone Fission's Avatar
1992 3.0, And as you can see why... somebody tapped into the black wire for aftermarket Tach operation. The wire is broke off flush. I scratched around on the material surrounding wire and it's hard as a brick. Can't dig the remaining piece out. Truck doesn't run any different and only thing that doesn't work is the Tach. Must the wire be fixed, what else does it affect? Any other way to fix besides splicing in another connector?
Old Dec 27, 2018 | 01:17 PM
millball's Avatar
PM me your address and I'll mail you a good plug with several inches of pigtail that you can splice in.
Old Dec 27, 2018 | 01:51 PM
Many thanks for the offer, but does that wire even impact anything else? If not then I won't fool with it so the other four wires stay intact.
Old Dec 27, 2018 | 02:29 PM
millball's Avatar
Not sure what the ECU might use that signal for.
Possibly for RPM limiter. Possibly for part of EGR control, IDK??
Old Dec 27, 2018 | 09:03 PM
Co_94_PU's Avatar
This rpm signal goes to three places in the schematic I have..
AC amplifier
Dash tachometer
Diagnostics port
The TCCS computer on the 3vz controls the ignitor at all times, so the ECU always knows the RPM, and this is an auxiliary circuit used for the "industry standard" ground switching tach signal.
Old Dec 28, 2018 | 05:17 AM
So maybe the wire only went "to tach" ?
Old Dec 28, 2018 | 10:43 AM
Co_94_PU's Avatar
From my 88 vzn manual..
Old Dec 29, 2018 | 06:26 AM
I understand now. Might try to solder or tack it back somehow on a warm day. Gonna pm millball too. Thanks y'all !
emmantik
Mar 14, 2014 07:35 PM
adahlin
Jul 29, 2013 08:31 AM
nv4runner
Feb 8, 2008 10:19 AM
Paul R. Haller
Aug 27, 2007 11:41 AM
