General Electrical & Lighting Related Topics Ask here for electrical, wiring, and lighting info for your rig that could apply to all years
Blown bulb or something else. No low beam , but high beam works.
Old Jan 13, 2014 | 10:37 PM
nuttynu's Avatar
So my low beam for the driver side is on. Right is off, but when on high beam mode. Both lights work?
Can it be a bad right bulb ? Or something else ?
Old Jan 13, 2014 | 10:44 PM
dropzone's Avatar
Fossilized
I'd start with the bulb..if they are an H4 style or type remember not to touch it bare handed, oil from your fingers can. Cause jt to either blow right away or shorten the life drastically
Old Jan 13, 2014 | 10:46 PM
nuttynu's Avatar
It's the whole hosing build. The 5x7.
That's what I'm thinking too.
Old Jan 13, 2014 | 11:05 PM
RAD4Runner's Avatar
+1 on bulb.
See schematic of stock 22RE (you did not say what year-model yours is) below.
Disconnect connector, measure resistance between pin 1 and 3. That's the resistance across low-beam filament. You should get very low resistance (couple of ohms). If open, your filament is burnt.
Pin 1 is where Red wire with green stripe goes.
Pin 3 is where red wire with white stripe goes.
(Also measure 2 & 3 if you'd like but not necessary).
Old Jan 13, 2014 | 11:16 PM
nuttynu's Avatar
Thanks you ^
It's a 93 pickup dlx v6.
I'll May trouble shoot with the new bulb since they're only $10 ish. Hopefully that's the case
Old Jan 13, 2014 | 11:55 PM
nuttynu's Avatar
Sylvania H6054 Standard Rectangular Halogen Headlight Bulb (Low/High Beam), (Pack of 1) : Amazon.com : Automotive Sylvania H6054 Standard Rectangular Halogen Headlight Bulb (Low/High Beam), (Pack of 1) : Amazon.com : Automotive
Old Jan 14, 2014 | 12:00 AM
dropzone's Avatar
Fossilized
I would convert to H4 Housings and put some PIAA bulbs or Silverstars in there.
Way better than any sealed beams. I was stationed in AK for 4 years, you wanna see that moose before it gets too close
Plus they have a better beam pattern to cut through the snow, HELLA housings are awesome
plus easier to swap out the bulb than taking apart half the grill..
Old Jan 14, 2014 | 12:23 AM
nuttynu's Avatar
Thank you for the info. The conversions deff sounds good , I may just replace and get they with it this winter and do the conversion this spring .
Old Jan 14, 2014 | 12:30 AM
Discombobulated's Avatar
The silver star 6054's are amazing compared to stock, much wider beam and way brighter I'm going to say just for the simple in and out swap you will be pleased
Of course you do have to buy 2 and they range 20-25 each...you can also search a bit on the housing upgrade as well, quite a bit more involved but I heard its worth the time
Sorry amazon wasn't giving me a link in there app.
Old Jan 14, 2014 | 12:33 AM
nuttynu's Avatar
True, the H4 is nice. But I already have hella 500, and rigid D2 as auxiliary lighting already.
Right now I'm just to lazy to convert anything. Plug n play. Alaska winter can make some of a lazy :/
Old Jan 14, 2014 | 12:34 AM
nuttynu's Avatar
These ???
http://www.amazon.com/gp/aw/d/B000C18Q4Y
Old Jan 14, 2014 | 12:41 AM
Nope, just the silver stars I have a pic edit above did It not come through ?
Old Jan 14, 2014 | 12:42 AM
nuttynu's Avatar
Just got it .!
Thanks. Hopefully the local parts store has em.
Old Jan 14, 2014 | 12:45 AM
The only place I have ever seen them is checker auto parts and I have rarely seen them at autozone, locally it's hard to say but hey if not amazon might be getting an order soon
Old Jan 14, 2014 | 12:04 PM
nuttynu's Avatar
Ordered from Amazon, local had them for $25, I can wait.
Old Jan 14, 2014 | 03:35 PM
Sweetness, you will love them I have trucklight LED's and they are really sweet but pricey before I upgraded I had them in my truck and from a standard bulb to the silverstars it's night and day The beam pattern is really wide and has a great cut-off.
Flying91
45
Apr 11, 2024 04:39 PM
Esibnitsud
Jul 30, 2015 08:21 PM
kcaudill
Jul 20, 2015 12:06 PM
kyletbert
Jul 17, 2015 11:39 AM
Coreyr384
Jul 10, 2015 11:13 AM
