General Electrical & Lighting Related Topics Ask here for electrical, wiring, and lighting info for your rig that could apply to all years
Best way to butt connect 8 gauge wire?
Old May 1, 2006 | 07:49 AM
mt_goat's Avatar
I have 8 gauge leads on my stereo amp and I need to extend them to the battery. I've always heard that soldering makes the best connection, does this hold true for large wire too? If so, got any tips on soldering these fat wires? Or should I just get some crimp connectors and call it good?
Old May 1, 2006 | 08:07 AM
Cebby's Avatar
I like to sort of weave the wires together, solder and then cover with glued heatshrink for a waterproof connection. I typically expose about an inch plus of wire on both pieces to make it easy to work with.
Old May 1, 2006 | 09:43 AM
mt_goat's Avatar
So when you're done are the wires side by side or end to end?
Old May 1, 2006 | 11:16 AM
BajaRunner's Avatar
Id guess twisted together, side by side.
Old May 1, 2006 | 11:18 AM
Cebby's Avatar
I do it end to end.
Old May 1, 2006 | 11:43 AM
mt_goat's Avatar
Originally Posted by Cebby
I do it end to end.
Ok thanks, I'll have to give that a try
Old May 1, 2006 | 11:55 AM
Corey's Avatar
Co-Founder/Administrator
The best way to extend it?
Get yourself a fused box like I have.
Run the amp end of it to the fused box, then run a new cable from the box to the battery.
I would also have it fused up by the battery too though.
50 amp fuse in the fuse distro box for the bass amp, and a 30 amp fuse for the door speaker amp, and a 100 amp circuit breaker within 18" of the battery.
You can see my positive distro box feed two amps, and the negative box also takes care of the negative side of things.
The negative one though is not fused, no need for that.
Old May 1, 2006 | 12:13 PM
GSGALLANT's Avatar
To splice two large wires together, you can get non-insulated crimp-on butt connectors. I usually apply a some soldering flux paste to the wires, put both wires into the butt connector and crimp them in. Then, heat up the butt connector with a torch enough to melt solder and apply solder to both ends of the butt connector until it is full. Let it cool off, then wrap the whole connection with water proof heat shrink. That'll be stronger than the original wire.
Old May 1, 2006 | 02:52 PM
mt_goat's Avatar
Thanks guys, yeah my soldering iron wasn't up to the task, not enough heat. Think I'll try to find the non-insulated crimp connectors and torch idea.
Old May 1, 2006 | 04:47 PM
mt_goat's Avatar
Corey I do have fused blocks like those, I just have to get over to them. Thanks
steve miller
Oct 10, 2015 01:40 AM
gary4runner
Sep 24, 2015 12:53 AM
v_man
Jul 23, 2015 04:01 PM
88yodabasket
Jul 13, 2015 01:32 PM
Poncho0206
Jul 10, 2015 06:21 PM
