General Electrical & Lighting Related Topics Ask here for electrical, wiring, and lighting info for your rig that could apply to all years
PLEASE HELP!Must remove fuse to remove ignition key
Old Apr 5, 2006 | 08:29 AM
randyman_ar's Avatar
Unhappy PLEASE HELP!Must remove fuse to remove ignition key
I have an 02 Tacoma. The ignition key will not lock and can't be removed. Tried wiggling,jiggling key and shifter with no luck. Digital clock drained battery so I removed the fuse and key returned to lock and can be removed. Put fuse back in .... same results, key won't lock and can't be removed. Anyone know the cause and cure for this? Thanks for any advice in advance.
Randy
Old Apr 23, 2006 | 06:30 PM
fireteacher's Avatar
you said you jiggled the shifter, my runner sometimes i have to push the shifter forward after its in park. try about 15-20 percent extra uuummmppphhh! if not that then good luck!
Old Apr 23, 2006 | 06:58 PM
Tanto's Avatar
If it's an automatic, check to make sure that your shifter is definitely in Park. I know mine won't let me take the key out unless it's in park.
Old May 1, 2006 | 07:32 PM
status????????????????????????????????
80Truck
Oct 12, 2025 07:25 PM
theking11863
Mar 19, 2016 09:36 PM
TDonkey
Jul 26, 2015 10:14 AM
rushw
Jul 18, 2015 01:46 PM
Hamonacracker
Jul 17, 2015 08:33 AM
