General Electrical & Lighting Related Topics Ask here for electrical, wiring, and lighting info for your rig that could apply to all years
Battery and Brake light just came on....? What does it mean?
Old Oct 20, 2009 | 05:09 PM
helidriver's Avatar
My wife was driving the 87 sr5 22re and the battery and brake light came on on her at the same time. Is this something specificly complicated or just have battery and alternator bench tested? Or are the two radomly unconnected?
She also thought that when she made it back to the house that she saw steam and the over heating "gurrling" but the temp gauge was normal?
On a side note is it a battery warning light or an alternator warning light???
Old Oct 20, 2009 | 05:44 PM
DeathCougar's Avatar
The search feature will yield the results you desire
Old Oct 20, 2009 | 06:47 PM
bruzer's Avatar
Have the charging system checked. That batt/alt light comes on when the system drops below a set voltage.
Old Oct 20, 2009 | 06:52 PM
olharleyman's Avatar
Pull your alternator and check the brushes sounds like they need replaced if so 4crwaler.com is the place to go for the replacement brushes
Old Oct 20, 2009 | 08:03 PM
4Crawler's Avatar
Sorry, don't carry the alternator brushes (do have them for the blower motor), but see below for a writeup of the repair:
- http://www.4x4wire.com/toyota/mainte...nator_brushes/
Old Oct 24, 2009 | 01:50 PM
helidriver's Avatar
thanks to all. I've been laid up in the hospital for some knee infection removal surgery. So I will pull the alt and have it bench tested and hope it hasn't killed my battery.
Old Oct 24, 2009 | 01:52 PM
Kiroshu's Avatar
Clean your battery terminals first thing! After that if its still on check further your alternator and brake system for leaks and low fluid..... Loose or brake resivor cap off?
Old Oct 24, 2009 | 06:20 PM
poynter's Avatar
if the alternator stopped charging and the truck overheated at the same time the belt probably snapped or the water pump locked up. I just had the same exact thing happen with the two lights and you could tell that the engine was being held back a bit. I ended up replacing the water pump, belts, tensioners, fan clutch and I took my alt to a rebuilder but it was in good shape.
Old Oct 24, 2009 | 10:35 PM
Agent Orange's Avatar
X2 on the belt. I lost one offroading several years back and had the exact same symptoms.
ashersullivan88yota
Jan 18, 2022 05:37 PM
jasonty
41
Dec 23, 2018 01:00 PM
fountain
Dec 31, 2015 06:08 AM
Sandman
Jul 14, 2015 12:36 PM
Johntom240
7
Jul 13, 2015 12:18 AM
