General Electrical & Lighting Related Topics Ask here for electrical, wiring, and lighting info for your rig that could apply to all years
back window doesnt work
Old May 18, 2009 | 01:14 PM
4Banger's Avatar
1st gen 4Runner an the back window will not roll up or down anymore. the back windsheild wiper still work so it cant be the relay right?
Old May 18, 2009 | 01:43 PM
griffin1340's Avatar
Can't say for sure if they are the same, but on my '91 the back window stopped working because the track popped off. Window would still try to come up/down but the power would stop before it got too far. [safety feature?]
I searched far and wide for new regulator guides...even tried to have anew back window installed by 'Little Red Truck'. They use the existing guides...
Finally went to salvage yard and bought new/better back window with good guides, seems the guides normally rusted out and the little regulator wheel would pop out.
So now I have a nice back window [had to buy the whole thing] in the garage just waiting to have a use for it!
The window regulator/assembly is a PITA to work on but it can be done. If you can get the window down you have half the battle won. You can access the regulator through the panel in the tailgate and usually pull the window down enough to lower the gate, then it's just getting into it to work.
Old May 18, 2009 | 01:56 PM
OrRunner's Avatar
I had a similar problem, my wiper worked ect. but the window would not go up or down, after messing with the wiper in the back i found that if the wiper would not go back up to the little magnet that holds it up, the window would not move, i just put the wiper above the little black magnetic "catcher" and it seemed to work fine, i dont know if there is a sensor that wont let it move when the wiper is down but i have not had a problem since. Kind of makes sense (you cant roll window up or down with the wiper going) so i figured it was a sensor, good luck hope this helps some
Old May 18, 2009 | 02:49 PM
4Crawler's Avatar
http://www.4crawler.com/4x4/CheapTri...arWindow.shtml
Old May 18, 2009 | 10:06 PM
4Banger's Avatar
now the light on the dash that tells you your tail gate is unlocked when the window is all the way down comes on every time i hit a bump
Old May 20, 2009 | 06:09 PM
4Banger's Avatar
Bump. I need help! It isnt the wiper or the sensor for when the top is off
Old May 23, 2009 | 11:52 PM
wyoming9's Avatar
Talking
well it can be a whole bunch of things.
you are testing with key in the on position if you are using the console switch.
Yes there is a safety switch on the wiper if that is open it will not work.
Did you lock the widow or has the lock switch failed in the open position.
It will not move in either direction from the key switch on the rear hatch or the rocker switch correct.
It can be broken wires in the area of where they go in the hatch . a failed motor a failure of any of the switches a bad relay a bad ground .
You just have to start some where and see if the motor works jumper a hot wire to it and go from there .
If you need wire colors I have the Electrical manual if you need more help pm me
Old May 23, 2009 | 11:57 PM
4Banger's Avatar
well i think it was just a loose connection cause i put power into the motor an it worked installed it again an everthing worked fine
aciorba23
Jun 29, 2015 04:18 PM
sharrack
Jun 26, 2015 09:33 AM
gog1968
Jun 22, 2015 05:55 AM
