General Electrical & Lighting Related Topics Ask here for electrical, wiring, and lighting info for your rig that could apply to all years
90 Runner will not turn over
Old 02-23-2013, 10:58 AM
91 4Runner's Avatar
Here's the deal - the 90 4Runner 3.0L auto (that I just picked up) won't turn over by using the key (neutral or park). If the key is in the run position and I jump the black/white wire under the hood by the battery it will turn over and start. What do you all think the issue could be?
Thanks for any help!
Larry
Old 02-23-2013, 12:21 PM
4Crawler's Avatar
See below for a quick test to point you to the cause:
- http://www.4crawler.com/4x4/CheapTri...shtml#EasyTest
Old 03-13-2013, 05:05 AM
91 4Runner's Avatar
Thanks 4Crawler.
Figured it out without too much fuss.. I did a bit more searching and once the weather was nice, so I fixed it.
I was staring at the manual, looking on the net, then back and forth between the 2. I decided that my symptoms sounded more like the Neutral Safety Switch . I removed it, cleaned all oil and crap off of it. This is when I noticed the rather large crack in the back. Took it apart and all the contacts were corroded, so i sanded/cleaned the grease, re-greased and reassembled. Then I sealed the crack with a layer of JB Weld to keep the moisture out. Reinstalled and turned the key and it started.
Now onto the next issue - the rear window.....
GreenLion
06-07-2021 10:49 AM
Cesarl74
04-23-2016 06:07 PM
Gamble_STi
07-01-2015 12:51 PM
rbravo1
06-29-2015 01:34 PM
sharrack
06-26-2015 09:33 AM
Quick Reply: 90 Runner will not turn over
